COE Rebel 9+3 harness
Discussion in 'Off Topic Hot Rods & Customs' started by iwanaflattie, Dec 1, 2016.
  1. iwanaflattie
    iwanaflattie
    Hey guys.
    Will a rebel 9+3 will work on my coe?
    Ive got,lights, maybe radio,turn sinals,maybe wipers(most likely going with vacuum)electric fuel pump,and maybe electric fan.
    Thks
    neverdun likes this.
  2. There is a guy on the hamb that calls himself crazy steve, he did a big write up about wiring and from my bit of knowledge, knows his stuff. Someway I lost his bookmark, but here is a worksheet that will show how stuff gets split up.
    I have a 20 circuit harness, but I plan to be pretty street roddy before I get done. Seat heaters, heated mirrors, etc.
    ****, for some reason this site won't let me load a jpg that I downloaded from here, I'll work on it.
  3. shopdawg
    shopdawg
    from alberta
    Seth- Most of the aftermarket systems are very similar, I've used Ron Francis(overpriced) Painless (too small of printing on wire) as well as Rebel. For the money I feel Rebel is a good choice for you and for what your hooking up.
  4. iwanaflattie
    iwanaflattie
    thanks Guys..
    I know we've been over it a few times on my thread but for some reason i dont stay focus or life gets in the way and plans or part lists get changed or lost..
    Im back at it again,trying to get the major fab done so i can take it so someone in las vegas to wire it and go over it in case i under engineered something.
    Replace brake lines tomorrow,rebuild rear drums,and finish my trans crossmember mount.
    Bbq some honey chipotle ribs with a mexican hot sauce rub,couple of blue moons and maybe have time to modify my front crossmember.
    Then finish my column shifter i made from scratch and install power steering pump, ps hoses, pcv valve,breather,bleed brakes.
    Finally have money to buy a radiator,battery ,wiring harness and the 700r4 tv and lock down.
    Ive been investing my money on trips and other useless stuff but its time to run the last stretch home.
  5. RMR&C
    RMR&C
    from NW Montana
    I used the Rebel 9+3 in my Coe...it worked fine but I wasn't crazy about the fuse box. No cover or easy way to mount it. And the rear light wires were to short naturally...
    For less money the Speedway(made by painless I think) 12 circuit is almost identical with a better fuse box, It uses those tiny fuses though. I used one on a previous build with no issues.
  6. shopdawg
    shopdawg
    from alberta
    Here's the one I bought for Sled Zeppelin. I bought it on sale at Speedway and think it was about 150.USD 100_1866.JPG 100_1865.JPG
  7. iwanaflattie
    iwanaflattie
    Cool guys that males it easier..will go for the speedway one!
    Thank u!
  8. iwanaflattie
    iwanaflattie
  9. iwanaflattie
    iwanaflattie
    So to fuse this with the wiring thread im going to make a list of what i will be using as electrical components.
    The speedway 12 circuit WH.
    The fuse will be mounted like this:
    It will mount it on the firewall somewhere so the power_kraft can be seen.
    Im thinking of running all these...we'll see.
    Tailights
    And these behind the ones above
    Kinda like this if u get the idea
    License plate light and bracket
    Might run these..i might not...i dont want it to look too busy...
    I also have have some fog lamps and a 3rd STOP light .
    I ordered light switch,dimmer switch,ignition switch and thats it.
    Am i forgetting something?
    JOYFLEA likes this.
