Hot Rods Rebel Wire Support.
Discussion in 'The Hokey Ass Message Board' started by GordonC, Apr 24, 2018.
  1. goldmountain
    goldmountain
    You really can't use a simple toggle switch for the turn signals because it won't switch out the brake circuit at the same time it is engaging the turn signal. You need a real turn signal switch. That being said, at one time I managed to get a system to work using two spdt switches that didn't have a center off position, but that was a lot of fooling around
    Sent from my SM-T350 using The H.A.M.B. mobile app
  2. GordonC
    GordonC
    I have found that out, although I figured using the trailer converter, as per a previously posted schematic, would allow it to work. Thanks.
  3. GordonC
    GordonC
    Jim I believe what you are saying, just that with the converter above and the toggle switch I had used (per the posted schematic) I couldn't get a turn signal function. The lights would come on but not flash. I'm waiting on a regular add on turn signal switch with lever to show up so I can wire that in and see what I get. Thanks.
  4. Johnny Gee
    Johnny Gee
    from Downey, Ca
  5. squirrel
    cool part....
  6. Wasn't there something about one of these suppliers "kits" concerning the turn signals????
    IIRC there was a wire in the fuse box that is on the wrong terminal causing an issue.
    If you do not have LED bulbs
    then the flasher unit should be getting power thru it to the light and see enough load to break over and flash the signals.
  7. GordonC
    GordonC
    Good News! Jeremy at Rebel wire called me this AM and spent some time on the phone with us going through some troubleshooting. He and I have come to the conclusion that the "trailer box" is no good. Everything was hooked up the way it should have been but we were getting no output from the box to the brake lights. He said he has seen this before and suggested that for ease of install, because I already have a toggle switch, that I get the American Auto wire switch. He felt that would solve my issues.
    As an FYI for others out there they had power problems at their shop. It seems a power pole had gone over on Friday in a wind storm and taken out their electricity, phones, and internet. He told me they were just now getting back out from under the backup this caused. Good guys! Very helpful!
    Johnny Gee likes this.
  8. Johnny Gee
    Johnny Gee
    from Downey, Ca
    Yes it is. It's neat that Rebel suggest's it also. But you knew right off what OP's issue was. The output from the brake switch and it's interaction with the turn switch or lack of interaction per a proper switch. This always seems to become a head scratcher for some.
  9. GordonC
    GordonC
    A follow up for the folks still here... a regular hang on the column type turn signal switch showed up today via UPS and when we wired it in per instructions we automagically have turn, brake, park and hazard lights. It seems the box we used was the issue. I really appreciate the help folks offered here as I was finally able to, after 4 years, take my "first ride" up and down the street today!! :D You can't knock the smile off my face with a hammer!! Here's some proof!
  10. buck 32
    buck 32
    from Maryland
    Good deal, glad it worked out for you. You have my luck, getting a bad trailer wire box. Good luck. Like your bad *** ride.
  11. pat59
    pat59
  12. squirrel
  13. Ranunculous
    Ranunculous
    I bought my wiring set up from Rebel Wire and am very happy with it.Called their phone number one evening and one of the fellas was eating supper(sorry to interrupt your victuals!) and answered all my questions and shipped a supplement I needed immediately.
    Great folks,great product.I'd buy from them again.
  14. GordonC
    GordonC
    Me too! They were great on the phone. Patient while working with a novice and very helpful.
