Technical Rebuild or replace my steering box
Discussion in 'Traditional Hot Rods' started by spillaneswillys, Jul 20, 2015.
  1. Please help me out, I have all most all of the bugs worked out on the hot rod but the steering box has 3 miles of play in it. I have been told it is a 53-6 Ford truck box. Should I have it rebuilt or go another way and if so what would be the best replacement with out a lot of work?
    thanks,
    Joe IMG_0012.jpg View attachment 2957172
  2. tb33anda3rd
    tb33anda3rd
    my vote is to rebuild the box.
    is the play in the u-joints? when going down the road straight is the box in the middle of it's travel?
    to test it, drive it and note where the wheel is when going straight. jack it up, pull the drag link off and count the turns of the wheel "lock to lock". divide by two and rotate the wheel to center, this is the spot on those boxes that are the tightest when adjusted correctly. the drag link should line up and the wheels should be straight.
  3. sawbuck
    sawbuck
    from 06492 ct
    it may be flexing,the way the mount is welded to the frame.just a thought..
  4. timwhit
    timwhit
    I'm with sawbuck. It may not be the whole issue, but may very well contribute to it. The box is easy to re-do. I put worm gear and bearings in one I had in a '32 p.u. and really improved it.
  5. wbrw32
    wbrw32
    Looks more like a Model A by the pitman arm..
  6. F&J
    F&J
    Didn't the A have a square shaft, instead of round?
    To me, it looks like a F100 53-up
    anyways...those old truck boxes have a very wide ratio, so any wear will really show up at the steering wheel. Like tb33 said, make sure it's centered (after you rebuild it).
  7. Rocky
    Rocky
    Classified Editor
    It's a 53-56 F-100 box alright
  8. 1931fordtruck
    1931fordtruck
    That's by far not an A box. I just got done taking mine apart in my '30 coupe. Going to stick with the original column and adapt to a saginaw steering box.
  9. deathrowdave
    deathrowdave
    from NKy
    F100 box , box needs reinforcement one way or the other
  10. HOTRODPRIMER
    HOTRODPRIMER
    Correct me if I'm wrong but it looks like this bolt is loose. HRP
  11. Mr48chev
    I'd agree HRP that something is out of kilter with that bolt.
    I don't like the lack of a gusset on the mounting bracket just as others mentioned.
    To Spillanewillies, I'd suggest starting at the top U joint and have a helper rock the steering wheel back and forth gently while you look for slack and or movement in each connection in the whole steering system. Hold the shaft and check each section of the U joints then check to see how much the steering shaft turns before the pitman arm moves then check each rod end on out to the tie rod ends. You may find that all the movement is in the box or one connection or you may find that you have a bit of movement in several spots that is adding up to what you are feeling with the wheel.
  12. Chucky
    Chucky
    I can't speak for loose, but those bolts aren't grade 8. Lock nuts / lock washers may be missing too. Not trying to pick on you / just trying to help.
  13. bgaro
    bgaro
    early ford store has the rebuild stuff for that box, then you'll know what you've got. defenitley worth a rebuild. beef up the frame mount, and check the joints for play when you got it apart.
  14. gonzo
    gonzo
    What @bgaro said, also some of the internals on that box can be salvaged from any early Ford cross steer box. If you don't have the Vern Tardel book on steering boxes its worth a read before you get started.
  15. sport fury
    sport fury
    www.stangerssite.com is a good source for steering box rebuilding.
  16. 57countrysedan
    57countrysedan
    from NY
    Can u adjust that box? I could be wrong but every vehicle I've had I was able to adjust some slack out
