Technical Rebuilding worn door latch.
Discussion in 'Traditional Hot Rods' started by kimfmx, Dec 22, 2015.
  1. kimfmx
    kimfmx
    Anyone got experience with rebuilding the door latches. The latch block itself is badley worn, and im wondering if i should just build it up with weld.
    Have anyone tried this?
    Cant seem to find this latch unit anywere. Its on a euro 4 door v8 1932.
    Best regards
    Kim mortensen.
  2. HOTRODPRIMER
    HOTRODPRIMER
    That's the way Dave does that particular part when he rebuilds the latches. HRP
  3. kimfmx
    kimfmx
    Thanks. Ill to that then.
  4. 2OLD2FAST
    2OLD2FAST
    from illinois
    I'd think you'd want to use a "hard-surface" rod to build that up ..
    dave
  5. kimfmx
    kimfmx
    I always thought that mig welds turned out hardend.
  6. 2OLD2FAST
    2OLD2FAST
    from illinois
    Might want to check w/your welding consumable supplier there are rods/wire that have different carbon content that make them more or less wear resistant..
    dave
  7. kimfmx
    kimfmx
  8. bobbytnm
    bobbytnm
    Yes
    I've done it on my 49 F1 truck, its not too bad. Once you get the mechanism dis***embled you will find several parts that are worn and may need to be built up. Tear the thing apart, clean and inspect, apply spot welds to build up the missing areas, file back to shape, re***emble and lube and you're good to go.
    It looks harder than it actually is. You'll be glad you did it, it will make a world of difference.
    Good luck
    Bobby
    snopeks garage likes this.
  9. kimfmx
    kimfmx
    Thanks. Yes its worn all around. What about the rivits. Is rivits available for this or is it better just to give it a weld.
  10. sidevalve8ba
    sidevalve8ba
    That's what I did on the latches on my truck. They seem to be holding up well.
  11. 325w
    325w
    Sometimes you can just turn the rivet half turn and it's good. Tack weld it. Get some new springs also. Gentleman on the Ford barn has correct ones.
  12. john worden
    john worden
    from iowa
    All good advice.
  13. kimfmx
    kimfmx
    Thanks all. I have the path layed out now (-:
  14. G-son
    G-son
    from Sweden
    There's hard, and there's HARD. A MIG/MAG weld might end up a bit harder than the base metal, a bit harder to work with but nothing crazy - not really useful to prevent wear. Hardfacing is used as a protective layer to minimize wear on excavator buckets, rock crushers and such. They can easily be so hard a file would just slide over it without doing anything - well, the file might get damaged but that's about it.
    Before someone pulls the "traditional card", hardfacing was used on the sealing edge of engine valves during WW2, giving a much longer valve life. If i recall correctly, it was used on flathead V8's running generators, but I might have mixed that up with something else.
  15. nunattax
    nunattax
    weld it up and get someone to clean it up on a milling machine,fresh springs if possible with fresh grease.i did the locks on my 38 chevy pu.turned out great
  16. NOS latch mechanisms are not terribly hard to find.
  17. bobbytnm
    bobbytnm
    I was able to reuse my springs, but a lot of the time the springs are broken. Be wary when buying new ones, make sure to match them up with the old. I know for the 48-52 Ford trucks the majority of the springs being marketed are wrong and would never work.
    On my latch mechanism it was held together with tabs that got folded over. These are pretty brittle and snap off very easily, I just spot welded it back together. I figured it lasted 60 years originally so it should probably be many a year before anyone has to mess with it again.
    Bobby
    Johnboy34 likes this.
  18. drptop70ss
    drptop70ss
    from NY
  19. kimfmx
    kimfmx
    Thanks. Great illustrated info.
  20. bobbytnm
    bobbytnm
  21. kimfmx
    kimfmx
    Yes. Thats exactly what ille attempt whe time allows (-:
  22. HOTRODPRIMER
    HOTRODPRIMER
    New springs are available,Dave turns new pins and rivets on a lathe.
    All the buildup is done with a mig before he reshapes it.HRP
  23. nmpontiac
    nmpontiac
    from Taos, NM
    I had to rebuild both latch mechanisms on the 30 Plymouth sedan I'm restoring for a client - they had the tabs that broke right off when I tried to bend them back, so I just welded them back up. They have compression springs inside them so I found some at the local Ace and trimmed them to fit. Fixed the droopy door handle problem and they work fine.
  24. kimfmx
    kimfmx
    Regarding the lock mechanism. On the european model its mounted with 3 of these on the back. I think they are used elsewere. What are they called and where to get them.
  25. alchemy
    alchemy
    Very similar to the washers that hold the insulation to the inside of the firewall. Not sure about the size/depth variations though.
  26. kimfmx
    kimfmx
    Do you know the name of such a thing (-:
  27. David Gersic
    David Gersic
    from DeKalb, IL
    I think "cup washer" is the name you're looking for.
  28. kimfmx
    kimfmx
    Super thanks.
  29. They look curiously like drum brake spring retainers?
    David Gersic likes this.
  30. kimfmx
    kimfmx
    Agree. But cant find any. Have searched the whole wwww.... complete from one end to the other. I think ill have to make one. When im done with that i will learn where to find them for 1$.... usually the way it happens (-:
