Technical Rebuilding worn door latch.
Discussion in 'Traditional Hot Rods' started by kimfmx, Dec 22, 2015.
  1. kimfmx
    kimfmx
    Maybe we are in furnature or coach building trade. Also found flush washer and finishing washer...
  2. kimfmx
    kimfmx
    But nothing that matches
  3. David Gersic
    David Gersic
    from DeKalb, IL
    It looks like something a jig and a hydraulic press could turn out from flat stock. Making the jig would take some effort, but then you could have dozens of them a few minutes later.
  4. Joliet Jake
    Joliet Jake
    from Jax, FL
    Weld it with standard/regular mild steel filler wire. Works great. Using a "hard" or "alloy" wire will prematurely wear down the other part it rubs against.
  5. kimfmx
    kimfmx
    David. Was also thinking about the press solution. Ill try to have two parts made to make it. It should be fast in a lathe.
  6. Rusty O'Toole
    Rusty O'Toole
    I have repaired similar latches by brazing. The bronze is easy to build up, easy to file to shape and wears well. I am not saying it wears as well as hardened steel but your car is not going to have daily use and abuse to contend with either. Braze it and it still will be good as new as long as you own the car.
  7. kimfmx
    kimfmx
    I think welding it is easier. Once its filled to fit at onecsurface its no go re brazing another side as it will destroy the finished side.... and i would have to have my gas refilled (-:
  8. kimfmx
    kimfmx
    Rewelding done.
  9. 2OLD2FAST
    2OLD2FAST
    from illinois
    That oughta work !!
    ave
  10. chrisp
    chrisp
    I may have a couple of those washers from my deuce, need to check in my pile. If I have some they're free.
  11. kimfmx
    kimfmx
    Chris, that would be superb. I only need one...
  12. edwardlloyd
    edwardlloyd
    from Germany
    I think I have some of those cup washers for a Euro Sedan. I even know where the door latches are. PM me if still needed.
