Rebuilt Chrysler FirePower Hemi & 700R4 Transmission
Discussion in 'Parts For Sale' started by ClutchDumpinDan, Dec 12, 2025.
  1. ClutchDumpinDan
    ClutchDumpinDan
    City: Fredericksburg
    State: Virginia
    Price: 9,000
    Fully Rebuilt Chrysler Hemi
    Turn key, ready to drop in and go, fully rebuilt Chrysler Hemi and 700R4 transmission. It has 30 minutes of run time on it to break in the camshaft. It’ll be on the run stand for a few more weeks if you want to hear it in person.
    331ci Chrysler Hemi was the core for the rebuild. The block was no good so a good 301ci Poly block was used. That was bored .125 over for a total of 320ci. Have all the paperwork for engine machine work and parts. No paperwork for the transmission rebuild. Engine machine work and ***embly was done in 2003. Engine was first fired and broken in on 11-21-2025. The valve covers are older chrome. Light scratches on them, some surface rust and a few bigger scratches as shown. Two of the spark plug tube boots are split.
    Located in Fredericksburg VA. I get to the Raleigh NC area fairly often and can bring along/meet up along the way.
    $9,000 for the engine and transmission. The run stand and engine mounts are not included.
    Block:
    Block was align honed and resurfaced
    Crankshaft shot blasted and turned .010/.010
    Ross pistons 3.750 diameter
    Connecting rods shot blasted and reconditioned
    Sealed Power main, rod and cam bearings
    Milodon oil pan
    Hot Heads high volume oil pump
    Heads:
    331ci “Triple Nickel” Hemi heads rebuilt. Casting number 1556157
    Hot Heads severe duty stainless steel valves with hardened tips
    2” intake
    1.75” exhaust
    Rebuilt rocker shafts
    Cam:
    354ci Hemi cam reground by Comp Cams
    Intake gross lift .424
    Duration at .006 260
    Lobe lift .2795
    Lobe Separation 108
    Intake:
    Hot Heads 4 barrel intake
    Holley Street Warrior 600cfm carb with electric choke
    Hot Heads finned air cleaner
    Ignition:
    Mopar 340 distributor with Pertronix Ignitor conversion (no ignition box required)
    Pertronix Flame Thrower coil
    Taylor 8mm plug wires
    Hot Heads distributor hold down
    Exhaust:
    Polished stainless steel headers 1 3/4” tubes, 2 1/2” collector, 3/8” thick flange
    Misc Parts:
    Hot Heads modified and remanufactured 340 harmonic balancer
    Hot Heads crank pulley
    Hot Heads low mount alternator bracket with GM 1 wire alternator
    Hot Heads valley cover
    Hot Heads timing cover
    Hot Heads BBC water pump adapters
    Hot Heads water crossover
    Hot Heads rear water block off plates
    Hot Heads vertical oil filter adapter
    Polished aluminum big block Chevy water pump
    4 Offenhauser polished aluminum valve cover breathers
    Transmission:
    Rebuilt 700R4
    Hot Heads Hemi to GM transmission adapter
    TV cable with carb bracket and geometry corrector
    Steel dipstick tube with locking dipstick
  2. ClutchDumpinDan
    ClutchDumpinDan
  3. ClutchDumpinDan
    ClutchDumpinDan
  4. ClutchDumpinDan
    ClutchDumpinDan
