Rebuilt head no compression
Discussion in 'The Hokey Ass Message Board' started by mcmopar, Mar 12, 2014.
  1. OldBuzzard
    OldBuzzard
    I have never done anything with these engines but, it would seem there must be a way to FORCE the valves to seat (if they can) by removing the rockers or pulling pushrods.????????????
  2. my47buicksuper
    my47buicksuper
    from sunny fl.
    I'm surprised no one mentioned this the head could be warped or have high and low spots very possible too then you wouldn't have any comp because there is big gaps I've seen it many times even on New rebuilt heads especially the longer ones just a thought
    Good luck
  3. mcmopar
    mcmopar
    from Strum, wi
    Jeeps are known for cracking the head between plugs 3&4. Mine was cracked, this is why I got a different head.
  4. mcmopar
    mcmopar
    from Strum, wi
    Huston we have a answer, 6 bent valves, all intake. I never p*** the buck, but this one ****s. I got screwed, but I guess I just did not look close enough, in the end my fault.
  5. Did clearance issues do that ? or is it on you? Head has not been cut since last running, but has it been?
  6. Don's Hot Rods
    Don's Hot Rods
    from florida
    Probably happened on the other blown engine when they tried to save it with a valve job.
    Don
  7. Engine man
    Engine man
    from Wisconsin
    It's easy to tell when someone at a salvage yard is lying, their lips are moving!
  8. gimpyshotrods
    gimpyshotrods
    Sorry man. I was really hoping for a better answer.
  9. mcmopar
    mcmopar
    from Strum, wi
    Me to but, but at least I know what I need to fix. It sure makes a guy feel like a dumb ***. Thanks for all the help.
    Tony
  10. saltflats
    saltflats
    from Missouri
    Sorry to hear this. I have been keeping tabs on this one. I am thinking the bad thing is that this one doesn't sound like fun to work on.
  11. gimpyshotrods
    gimpyshotrods
    Intake valves are about $9/ea., regular or 0.015" oversize.
    My '96 4.0HO is about to make the 200K mark.
  12. mcmopar
    mcmopar
    from Strum, wi
    The wrangler in my avatar has 202,000 and the Cherokee was just bought for $500 for my 17 year old daughter and has 208,000.
    31vickey, I have looked at some of your builds in the past very nice work.
  13. Don's Hot Rods
    Don's Hot Rods
    from florida
    Eh, we've all done similar things......some of us more than once. :eek:
    Those 4.0's are a great motor and good performers for a 6. A decent valve job and you will be back on the road.
    Don
  14. INVISIBLEKID
    INVISIBLEKID
    from Gilroy,CA
    Don't sweat it- we ALL have to learn the hard way sometimes...repair it,and call it done.
  15. gimpyshotrods
    gimpyshotrods
    I have heard it said that wisdom is when you can recognize your mistakes when you repeat them.:eek:
  16. Don's Hot Rods
    Don's Hot Rods
    from florida
    Then I must be a very wise man. :eek::eek:
    Don
  17. gimpyshotrods
    gimpyshotrods
    Me too!
  18. prpmmp
    prpmmp
    Can someone explain what I'm looking at in post #64? I see small dark pieces at the intake valves(is it chunked out? Aren't bent valves bent at the stem? Thanks Pete
  19. I'm guessing that's a piece of shim stock between the valve and the seat.
    Usually the bend above the tulip and below the guide. Bending is caused by contact. Sometimes they stick first then get bent a split second later.
    The junk yard engine must have had a bad timing chain issue?
  20. mcmopar
    mcmopar
    from Strum, wi
    Correct those are pieces of shim stock, to show that the valves are not closing.
  21. prpmmp
    prpmmp
    Gotcha!! Thanks!! Pete
  22. Don's Hot Rods
    Don's Hot Rods
    from florida
    That is what I am thinking. The previous owner probably did have this head done but he installed it on the junk motor that had serious issues. The cam timing could have been so far off it caused the valves to kiss the pistons.
    The junkyard guy may have been telling you the truth as far as he knew it. That head looks like it has been redone at some point, but it was evidently damaged after that.
    Don
  23. Mr48chev
    I checked over on the Jeep Cherokee boards and that is "not" supposed to be an interference engine according to what I read.
    My guess is that someone used a hammer and socket with something hard behind the valves to pop the springs off to change the valve seals and bent all six valves exactly the same in the process. An off center spring compressor might do it too but bending all six that way sounds a bit of a reach.
  24. mcmopar
    mcmopar
    from Strum, wi
    Here is what I found on the head when I took it apart. I called the parts yard, they said I bent them, because they had the head checked. I talked to the shop that did the work they said that they only magnafluxed it. I talked to parts yard again and the guy says that they sell heads with the understanding that they need a valve job, I called ********. I then told them that the receipt say reman. head less than 1000 miles. He told me I have to talk to the owner, and he will be back on Monday. I figured I would get the run around, and I did. I just want them to sell what they say it is.
  25. gimpyshotrods
    gimpyshotrods
    This is not an interference engine. You'd have to really be trying to make sure this happen at home.
  26. john mullen
    john mullen
    Just out of curiosity why did you change the head if it hade 150 lbs or so of compression to start with??? and why did you not have the original head repaired? I'm not kicking you just wondering why
  27. Atwater Mike
    Atwater Mike
    Agreed. But after all is said, IF the junk yard owner won't make it good, you still have the valves out of the cracked head. Grind them and regrind the seats. (New valves? I'd weigh the options)
  28. mcmopar
    mcmopar
    from Strum, wi
    Antifreeze was getting in the oil from the crack by the rocker post.
  29. prpmmp
    prpmmp
    Thought it is unfortunate for you this thread has been very interesting to me(my sons vehicle has the same engine and same problem that we have to address) seems that the fix(although costly is to buy a new complete head,.new beefier casting) from Clearwater Head Service. Pete http://www.cylinder-heads.com/Home__.html
  30. :D Drop a SBC in that thing .
    Maybe a 5.3 swap :eek:
