recip air compressor pump id please, 1965?
Discussion in 'The Antiquated' started by green light, May 14, 2020.
  1. green light
    green light
    This pump was from a 1 hp 22gallon horizontal unit that sat on wheels. A slip of paper inside the now replaced leaky pressure switch had smc brand on it and manufacture date of 1965. The now replaced tank had a local retailer label slapped on the side. As the photos hopefully show, the flywheel has 3 fan blades with 1171 opposite an arrow to identify direction of rotation. There is a flat space on the side of the pump where it appears a label possibly once was but is no longer. Underneath the cast felt type filter cover plate is a 1203 and E2. On the lower corner of the crank case it says "oil level" in vertical letters and this is on the same side of the case that the oil dipstick is located. Opposite the side of the dipstick is the pump output and below the output just above where the crank case meets the piston encasing portion of the pump is ":4392:" or ":1392:"
    I'm trying to replace the gaskets and to do so trying to identify the manufacturer of the pump to find more information as well as parts. I believe this is a dual inline single stage pump as opposed to 2 stage but that is just my guess based on other pumps i see when searching online. I believe the old tank had sticker with output cfm listed around 9 @90psi and psi max listed as 175.
    This is my first time doing this if that isn't completely obvious already. Thank you very much to any info you can share regarding this air compressor pump
    IMG_20200512_013537556.jpg IMG_20200512_013547525.jpg IMG_20200512_013618443.jpg IMG_20200512_013631285.jpg IMG_20200512_013641189.jpg IMG_20200512_013653352.jpg IMG_20200512_013707687.jpg IMG_20200512_013742460.jpg IMG_20200512_013817707.jpg IMG_20200512_013827085.jpg IMG_20200512_013855867.jpg IMG_20200512_013916631.jpg
  2. green light
    green light
    i figured it out. it was made by sanborn (the "s" in smc)
  3. deathrowdave
    deathrowdave
    from NKy
  4. green light
    green light
    found:
    This is E.L. Smith (P.K. Linsdey subsid) was bought out by American Eagle as Model 84 (not model 84A) Very few parts can be found. However, many parts are replaceable with the 143 model (half of the V480) The disc valves are no where to be found! The newer version 84A on up has a 2 or 3 reed valve system and plates. Most were rated at max 165psi normal run 95-120. They are bullet proof! Good luck on what ever you decided to do... I have 2 of them myself.
    https://www.practicalmachinist.com/...l-smith-portable-20-gallon-compressor-277610/
