Recommend a small, lightweight battery!
Discussion in 'The Hokey Ass Message Board' started by modified, Jun 19, 2011.
  1. modified
    modified
    Building a closed cab A pickup w/383 SBC, lights & horn.
    I don't want to mount it under the floor....suggestions please!
  2. Dino
    Dino
  3. tooslow54
    tooslow54
    Powermaster also has some very light batteries. Compare everything, not just weight. Oops..forgot. Powermaster split. Look up XS Power Batteries. If you need a contact, PM me.
  4. swifty
    swifty
    Odyssey PC680 fits the small part but for it's size it is not light. Can mount it anyway except upside down. They use them in the V8 Supercars out here. They're definitely not cheap here, don't know what pricing is in the States.
  5. Old Gold
    Old Gold
    when I built my 46 Ford P/U, I used a Mazda Miata battery. Small enuff to fit under the dash and have access thru the glovebox. Had 650 cranking amps and ran my SBC and accessories with no problem.
  6. TheTrailerGuy
    TheTrailerGuy
    DO NOT... (I repeat DOOOO NOOOOOOTTTT) spend the bucks on one of those hi dollar Optima batteries!!!! I have spent the big coin on three different ones and if you let it get down to flat for any reason (leave the lights on by accident, forget to trickle charge over the winter... whatever) every single one i owned stayed flat and could not be brought back to life.
    Go to autozone, grab the book and start hunting the smallest with the most cranking amps in regular black case batteries. How about two Harley Davidson batteries run in tandem? I know a guy who did that on a rat rod to keep them hidden. Looked cool and could start a small block chevy any old time.
    Just a thought.
  7. CruZer
    CruZer
    Check out Performance Distributors. They sell a small battery for about $155. I know it's not cheap but it is very small and I have used them in two of my hotrods and they work .
    One lasted 8 years.
  8. thepolecat
    thepolecat
    1. S.F.C.C.
    Braille has one that is 6 pounds. I used them in my Civic for autocross events.
  9. Tommy's Cycle
    Tommy's Cycle
    from So Cal
    Braile. Excellent small battery.
  10. Hnstray
    Hnstray
    from Quincy, IL
    This is my recommendation too............
    Ray
  11. brigrat
    brigrat
    from Wa.St.
    Dyna-Batt, 13lb's, 7"L X 6 3/4" H X 3" W.
    Have a couple "A" running them behind the dash on firewall.
    Odyssey PC680 may be the same?
    Use a Battery Tender for storage .....................
  12. CutawayAl
    CutawayAl
    from MI
    On of the small race batteries mentioned is probably what you need. The trade-off is; those batteries aren't as rugged or durable as most "regular" batteries.
  13. the miata battery is the size of a lawn and garden battery case you were wondering, they are really pricey though... a 51 size battery is pretty small and they have some good cranking power too....
  14. chronisterracing
    chronisterracing
    from N.Il.
    Speedway has a Braille that is 7x3.5x6 at 15# not cheap though
  15. I've been running an Odyssey PC680 under the seat of my 29 RPU for 6 years now with NO problems.
    DO NOT put a lead acid "normal" type battery under you dash. If they over charge or you get in a wreck the acid could severely harm you or your passenger. Serious shit when it happens.
  16. Tommy's Cycle
    Tommy's Cycle
    from So Cal
    Hawker Energy makes the Dyna-Batt battery. You can buy it from Hawker without the fancy labels for just a little over 1/2 the cost of the Dyna-Batt.
  17. Don's Hot Rods
    Don's Hot Rods
    from florida
    Here is vote number 5 for the Odyssey PC680. Had one in my 23 and it was flawless.........could sit for months and still crank the 350 engine with no problems. Only measures 7 x 7 x3 inches and tucks anywhere.
    Don
  18. I have had good luck with the Odyssey, I have had a couple of them over the years and never had a problem,
  19. modified
    modified
    I'm impressed by the Odyssey PC680 and it's reputation. I've found a guy who pulled his PC680 out of his roadster after 17 years!!! He needed a battery for his lawn tractor and bought a new 680 for his car. I'm going with the Odyssey PC680!
    Thanks everyone for your imput!
  20. brigrat
    brigrat
    from Wa.St.
    17 years? Have they been making them that long?
  21. this is good info to have! i have installed a couple of those dynabatts in customer cars and had no problems, they are relatively small and worked good.
  22. Old Gold
    Old Gold
    I paid $68.00 for mine thru Interstate Battery w/lifetime replacement.
  23. If it starts real easy, I used a lawn tractor battery to start my 32 with 354 hemi.
  24. modified
    modified
    Quote from a guy I talked to yesterday:
    As far as a cranking battery, my PC680 is 17 years old, and the (3) different engines in the T were all 10.25 to 1 CP. I just pulled the battery today to use in a tractor for the yard that always seems to have a dead battery. I think I'll get a new one for the T and leave the 17 year old battery in the tractor.
  25. striper
    striper
    I use one with my 401. Also 10.25 :1 compression and it turns it no trouble.
  26. 48buickkid
    48buickkid
    nothing is wrong with the optima batteries i have multiple friends that use them you just have to recharge them in a wierd way if they go flat you have to have another good battery laying around that you hook to a charger then you hook that battery to the optima to charge it. there is stuff on the web about how to do this and these things usually last a long time unless your stupidly hard on them. also has anyone tried the hotrod batteries? the ones they always advertise in rod and custom? theyre about 11 pounds and the dimentions are small but theyre rated in horsepower? just wondered cause i thought about this battery for converting my buick to 12volts
  27. 64gtoguy
    64gtoguy
    What he said ^
  28. modified
    modified
    I went with a Braille battery, I love it!
  29. Keep
    Keep
    For the folks looking at the oddessy batteries (I know its late in your sitiuation)
    Call your local solar panel company, they are usually Odessy dealers as they use them in their systems and will give you a much better price then the auto shops.
