Technical Recommend good generic ignition switch?
Discussion in 'The Hokey Ass Message Board' started by mindheavy, Jul 22, 2014.
  1. mindheavy
    mindheavy
    from tulsa
    I putt around in a 1967 El Camino, hopefully my kind is welcome here... for several years I have been running this ignition switch from NAPA. It's been a good switch but has developed a potentially dangerous problem. The back of it, the black plastic part, wiggles around in the housing. Today I tried to fire up the car and nothing happened, like the battery was disconnected. I reached my fingers back there and gave a few tightening pushes and sure enough, that was it. It has done this before a time or two... I really don't want that part to ever pop out and let a live wire dance around behind my dash.
    Can anyone recommend a good quality generic ignition switch I can replace this with? Thanks
  2. HOTRODPRIMER
    HOTRODPRIMER
    There's really nothing wrong with the generic type of switch but it sounds like you might just have a loose connection. HRP
  3. chopped
    chopped
    I've used that one before, I'd just get another one.
  4. Just about any factory GM switch will fit that hole in the dash, why not use one of those? I've had NOS ones and if they're common they don't bring much on eBay.
  5. tommy
    tommy
    I'd use a reproduction factory switch. To my eye those look so cheap with that knurled retainer.
    squirrel likes this.
  6. 37hotrod
    37hotrod
    So-Cal sells a generic one that looks alot like that one, except the retaining nut is more attractive. Probably made in the same Chinese sweat shop.
  7. bobss396
    bobss396
    Some product lines that Napa sells are just out and out ****. Look for a direct replacement made by Niehoff or Standard Ignition.
  8. KoolKat-57
    KoolKat-57
    from Dublin, OH
    There are multiple companies that sell OEM quality repop switch ***emblies.
    That to me would be your best bet, no wires to cut just plug it in and go.
    KK
  9. tfeverfred
    tfeverfred
    Just replace it. You said it lasted several years? Well, in this day and age of, "Made in China", you made out pretty good. If it were me, I'd be hitting the swap meets or internet for a factory replacement.
    I have the same switch in my T Bucket and I HATE it. It works good, but it just looks WRONG. The key is no better. One day, when I'm bored and feel like tinkering on my car, I'm going to hunt down a gennie 50's - 60's switch and key. Details, man. It's all about the details. And nothing says, "cheap *******", like that $10 ignition switch from the "do hickey" aisle of the local auto parts store.
  10. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Had a switch go bad so off to the parts store. Nothing but Made In China stuff in the store. Seems like GM is having lots of ignition switch problems and guess where they are made. Ron Francis has a nice switch but I have not checked to see if it is made in China or not. You get what you pay for...
  11. squirrel
  12. Hnstray
    Hnstray
    from Quincy, IL
    Cole-Hersee makes a lot of electrical parts that are of very good quality. Many are Marine Grade.
    If you have an old school parts house in your area, they likely have a catalog.
    edit: just checked.....they have a web site (imagine that!) www.colehersee.com
    stimpy likes this.
  13. 52plybizcoupe
    52plybizcoupe
    from Brier Wa.
    Cole-Herse makes the best marine grade electrical components
    stimpy likes this.
  14. HemiRambler
    HemiRambler
    Looks very similar to the stocker in my Rambler (and probably 10,000 other cars), one time mine took a **** and started acting weird was because it had carbon tracked inside (burned into the bakelite) anyways I s****ed it clean and filled the void with epoxy. Recrimped it. That was 15 or so years ago still working. I figure it's BROKE now - why not try to take it apart check it out and recrimp - you may actually fix it - nothing lost if you can't - it's broke anyways.
  15. 39-2dr
    39-2dr
    from MISSOURI
    I almost bought the So-Cal switch but I would have to enlarge the hole in the dash and I didn't have the needed space behind the hole. The GM works good. I have used tractor switches in a pinch too.
  16. Don's Hot Rods
    Don's Hot Rods
    from florida
    Yep on Cole Hersee. The ignition switch and push pull switches in my 27 are over 25 years old and still work great and they have been wet a lot of times over the years. I'm in the marine business so I sell them and have never seen one come back. They are all br*** and made for the tough marine environment. All of Cole Hersee's products are first rate.
    Just go to some place like Westmarine.com and you will find 3 pole ignition switches and 4 pole if you want to be able to turn the switch backwards to run your radio with the ignition off. They sell for about $30 and free shipping to your door.
    Don
  17. stimpy
    stimpy
    I'll third the Cole Hersee stuff , we use it in heavy equipment that sits in the weather and on trucks that get beat to death , if your worried about hi amp in the switch use a remote relay to control the start function ( takes the big draw away from the switch ) then fuse the input side of the switch .
  18. notaford1
    notaford1
    from webster ny
    Standard ignition #US14...looks like the pic from mindheavy
  19. mindheavy
    mindheavy
    from tulsa
    Thanks for all the suggestions. Looks like I'll be ordering a 3-pole from Cole Hersee
  20. Using the exact same switch as you that I purchased from NAPA 7 years ago.
    Works excellent for me in my old roadster.
  21. 325w
    325w
    I'd get anNOS off evil bay
  22. tfeverfred
    tfeverfred
    They have several neutral safety switches too!
