Recommendations 5x5.5 bolt pattern for Mustang 2. ECI Brake kit?
Discussion in 'Off Topic Hot Rods & Customs' started by streetrodder51, Nov 5, 2024.
  1. Hi All!
    I have a '36 3 window that I recently bought back. Unfortunately it has a Mustang 2 front suspension. I need to put a narrower front wheel on it. I would like to go back to a original type '40 ford wheel. But the bolt pattern on the '36 is 5x4.75. I know ECI use to make a big brake kit for Mustang 2 with a 5x5.5 bolt pattern. But they no longer make them due to not much demand.
    If I could find a used ECI kit that would be great. If you know of anyone that may have one laying around.
    Or if there are any other suggestions to get the 5x5.5 bolt pattern on Mustang 2.
    I've done some searches but they usually bring me to a generic page with a generic photo of a mustang 2 rotor that only says its available in 5x5.5. Makes me a little Leary on ordering something from an unknow site.
    I posted over in the wanted section for the ECI kit but it got deleted.
    Thanks!
  2. squirrel
  3. deathrowdave
    deathrowdave
    from NKy
    Mr Squirrel , you are da man , thank you all the vast knowledge
    Deuces likes this.
  4. big duece
    big duece
    from kansas
  5. squirrel
  6. big duece
    big duece
    from kansas
    I believe your correct, but they show a "big brake" kit, must be just larger rotor.
  7. squirrel
    Yes, it's a larger rotor, compared to the stock 9" setup
  8. I will try and give him a call. But your right it does look quite old. Thanks!!!
  9. Deuces and big duece like this.
  10. enjenjo
    enjenjo
    from swanton oh
    Well there is a hubless Rotor used on the Chevy Trackers with that bolt pattern, but it would likely need a custom made hub. There is also the 1988 F150 hubless rotor but again it would need a custom hub
  11. I want to say the ECI kit used F150 rotors. But they don't have the description on their website anymore. I'll have to see if i can find an old catalog.
  12. Phillips
    Phillips
  13. I saw these as well. But a little Leary on the ebay stuff. Especially when it comes to brakes..
  14. 1biggun
    1biggun
    Samurai also uses a 5x5.5" disk .
  15. PotvinV8
    PotvinV8
    Call Fat Man Fab (704) 545-0369)
    They offer 5x5.5-inch packages and should be able to help you ID what you have and what rotor you need to make it all work together.
