Recondition a Steering Wheel?
Discussion in 'The Hokey Ass Message Board' started by Zuluman, Feb 23, 2007.
  1. Zuluman
    Zuluman
    I have some very small cracks in my steering wheel and also want to re paint it. Anyone had any luck with this???
  2. JDHolmes
    JDHolmes
    from Spring TX
    Yes. check out the search function for steering wheels. There's a couple of great threads there.
  3. flatheadpete
    flatheadpete
    from Burton, MI
    I'm doing an old Zephyr wheel right now. Used platsic welder 2-part epoxy to fill the cracks.
  4. 5window
    5window
  5. Tin Can
    Tin Can
    I recently redid mine, I wouldnt spend the money on the kits. There are some good tech articles out there. I followed them and used the 2 part epoxy log and some finishing putty when I got the inperfections small enough.
  6. Redline Rocket
    Redline Rocket
    from Rockies
    A few years back I paid a professional to restore a couple wheels- had problems with both. Did the next 2 myself- no problems. Lots of good tips on the board.
  7. No_Respect
    No_Respect
    from So-Cal
    Zulu Man welcome to hamb I used kitty hair and finishing filler on wheels in the past and havent had a problem, Do you have a windshield in her yet a couple of years ago i seen you driving her with no glass thats dedication
    Jared
  8. smokindave
    smokindave
    I also used the Eastwood stuff once, and it worked great for me.
  9. If the cracks are small, as you said- I would use Evercoat "Icing" a hardened spot/glaze putty.
    It works well and will last PLUS it is real easy to sand down....
    I would then use PPG delstar enamel with hardener and add FLEX agent, to give it flexibility.....
    I have done several with this and it lasts well.
    note-DO NOT PRIME the wheel-just paint it, the primer may crack....
  10. Frank
    Frank
    I had a guy today tell me he used bowling ball cement. I've never seen the stuff before but it seemed he might be on to something.
