I'm not having any luck finding a swatch for DP's Red epoxy primer(dp74lf) Can somebody who has painted their ride in this color throw up a pic or two so I can get an idea on what the red looks like. DP is a non sanding epoxy primer made by PPG from their Deltron line(if that helps) Thanks
Hot rod flatz carries a single stage PAINT to simulate the red oxide...and it wont be porous like primer if you're planning on running it that color.
If you are planning on running it as the final topcoat, please know it has very little UV protection and will fade out somewhat quickly on you. The black DP 90 will gray over time and I imagine the red would end up a washed out red or maybe even pink. Don
