Red Dykem Layout Liquid?
Discussion in 'The Hokey Ass Message Board' started by JPMACHADO, Aug 8, 2008.
  1. JPMACHADO
    JPMACHADO
    from Not Listed
    I went to get some ****m today, I'm attempting at making some brackets. Is there a difference between the Red ****m (that I purchased) and the blue (that I've seen used before)? The machine place only had the red, but it has a bottle brush and everything like I've seen with the blue. Thanks
  2. squirrel
    It's a different color. Some guys can see one or the other better. Other than that I don't think there's anything different.
  3. Same ****!! Open the bottle stick your nose in get a big wiff and design some cool-****>>>>.
  4. gas pumper
    gas pumper
    Mix the red and blue and you get a cool purple ****m. I've dipped dash bulbs in it, after breathing the fumes.:D
  5. I had a dude that worked for me that used to walk around with bottle wiffin on it constantly. After about 9-0clock I couldn't get him to do ****!!>>>>.
  6. brawler500
    brawler500
    from Roxbury NJ
    Blue is great for cold rolled steel and aluminum because of the color contrast. If you are using hot rolled steel, red makes the line easier to see.
    David
  7. 392_hemi
    392_hemi
    All the same, just different colors. My buddies and I use different colors on the heads of our ammo when we go shooting. When we're done, we sort the br*** by color and everyone gets their br*** back for reloading.
  8. Homemade44
    Homemade44
    They are the same, but the red has a longer shelf life.
    Joe
  9. JPMACHADO
    JPMACHADO
    from Not Listed
    Thank you very much to everyone who replied. I just wanted to make sure I wasn't getting into something that was going to cause a problem.
  10. Crazydaddyo
    Crazydaddyo
    I used some blue ****m once when I was an apprentice to tint my safety gl***es. I was working outside fabing something up and the Safety Nazi wouldnt let me use sungl***es.
  11. gaschevy
    gaschevy
    No difference and they even have opaque white. The Rod
  12. noboD
    noboD
    I quit buying ****m years ago, use a magic marker.
  13. zombo27
    zombo27
    from E-town Ky.
    I have never bought it. I get it "free" at work.
  14. ems customer service
    the red gives a better high
  15. DCarr
    DCarr
    I did OD grinding for a bit and we always used red ****m on the bad dianmeters and the blue on the good. And to this day I still use it the same .... bad parts have the bad area marked in red so I can set up on the good diameters.
  16. Crazydaddyo
    Crazydaddyo
    Die makers use blue. Mold Makers use red.
  17. Blue Magic Marker works great on aluminum.
    Black Magic Marker on steel.
    For bigger jobs, ****m blue in a spray can.
  18. JPMACHADO
    JPMACHADO
    from Not Listed
    I'm sold!
    I've only ever used a sharpie to lay things out. The ****m with a scribe is awesome. All my brackets are identical (so far) because I wasn't trying to match tolerances to a 1/8" black marker line.
  19. So glad all the high tech advice helped out>>>>.
