Technical Red fuel line
Discussion in 'The Hokey Ass Message Board' started by Timothy Murphy, Aug 18, 2024.
  1. Timothy Murphy
    Timothy Murphy
    I am building a 283 with tri-carb setup and would like to run some what early ‘60s era look with the red plastic see thru fuel line. The product from Speedway says not to use gas with ethanol in it which I’m ok with.
    If you are running this fuel line have you had any other issues? Thank you
    dana barlow likes this.
  2. guthriesmith
    guthriesmith
    Mine made it about a year on my three Holley 94’s with non-ethanol fuel before it was pretty brittle. I swapped it out for regular rubber line fairly quickly. Although it looked cool, I heard too many stories about it failing.
  3. hrm2k
    hrm2k
    My engine builder found this hose through Grainger. Made for gasoline with ethanol…..so far so good IMG_1775.jpeg
  4. Jack E/NJ
    Jack E/NJ
    from NJ
    If possible, I usually try to avoid hoses on pressure side of pump.
  5. 427 sleeper
    427 sleeper
    ^^^^^^ THIS ^^^^^^
  6. Tim
    Tim
    from KCMO
    I’ve often wondered if you could find the red hose big enough to sleeve a metal line. Would look the same but less chance of fuel dumping all over when the red gets brittle.
  7. 56don
    56don
    I had some of that Speedway stuff and it got hard as a rock.Maybe the stuff hrm2k is posting would be a better product.
  8. lostone
    lostone
    from kansas
    @hrm2k how long have you been running it? Looks really good in the pics as far as any noticeable deterioration.
    @Tim that sounds like a very plausible work around ! Be interesting to see it tried.
  9. buford36
    buford36
    from Maine
    I have a friend who did exactly that --Ran brake line thru the red hose. When done, you could see red hose and the tubing allowed to make shallow bends.
    lowrd and hrm2k like this.
  10. Bandit Billy
    Bandit Billy
    I like that red line. Make sure your insurance premium is paid up and a Halon Extinguisher would be a good call.
  11. hrm2k
    hrm2k
    The engine was run in at the machine shop in March 2023. We emptied all 4 carbs after the run. It is sitting in the frame waiting for me to finish it. As life is currently going it should be finished a couple of years from next Thursday
  12. lowrd
    lowrd
    The suggestion Tim had works great, just warm up the hose before trying to put it over the tubing. The color does not fade at all!
    Tim likes this.
  13. fastcar1953
    fastcar1953
    Doe's it come in 1/2 size? :D:p:p:D I.d. please
  14. deathrowdave
    deathrowdave
    from NKy
    I had some on an Harley , fuel line went between the jugs to the carb . I learned a like long lesson , use the best and replace less . It was not a fun ride gasoline spraying in the face , eyes and mouth at speed . The fuel was gravity feed, just think issues if a pump was feeding it .
    Has anyone given and thinkin to stainless tube sprayed with candy paint ? Will it work , how will it work ?
    I just hate to see the car ruined or someone hurt from something we all know is subject to fail at any moment .
  15. Red powdercoat. Most is impervious to gasoline...
    Paint won't hold up.
  16. Jkmar73
    Jkmar73
    from Tulare, CA
    You can cerekote the tubes as well as powder coat.
  17. UNCLECHET
    UNCLECHET
    I had some of that red fuel line from Speedway on my '50 Ford years ago. I can't say for sure that I never ran the car on ethanol blend. Sometimes you get stuck and have to. The red line turned brittle and literally crumbled to the touch. I'll never run it again.
    mad mikey and 427 sleeper like this.
  18. jimmy six
    jimmy six
    Absolutely. Nothing but tubing and fittings from the fuel pump to the carbs. The only flexible line is from the frame to the fuel pump and no screw clamps if possible. The factory was smart and so should we be….
    Bandit Billy and 427 sleeper like this.
  19. mad mikey
    mad mikey
    Looks very nice.
    hrm2k likes this.
  20. This is the only time I ever used red fuel hose, no fuel ever p***ed through it ;)
  21. Jack E/NJ
    Jack E/NJ
    from NJ
    Nah. I'd use seatbelts to mount my kegs inside the car.
    akoutlaw and Bandit Billy like this.
  22. Bandit Billy
    Bandit Billy
    Do you get to use the HOV lane?
    Jack E/NJ likes this.
  23. HOTRODPRIMER
    HOTRODPRIMER
    Even the high quality premium fuel polyurethane red fuel lines caution to avoid gasoline containing 10% alcohol or ethanol.
    I used red plastic fuel line back in the 60's and never changed the lines, their failure resulting in a engine fire due to brittle lines and I almost lost my car, to this very day I love the look but since I now have a hood I use line made for cars that use diesel fuel, it last a lot longer than regular gas line. HRP
    TrailerTrashToo likes this.
  24. dana barlow
    dana barlow
    from Miami Fla.
    The stupid Gov. pushed corny gas* dose take the color partly out of sami-clear red line after about a year. { Speedway sells},but the sun* also dose,if not garage kept.
    Plus it starts getting hard,flex is less=becomes likely too crack if bent=not a good thing.< replace before this can happens. When the red turns to OJ,then yellow, time to get some new red. You can feel it get hard too.
    I've been running it for many many years,started in the early 60s,,but I do change it each year. A few times in the p***ed ,it was not EZ to get ,and I used just black line,but I like the look of red*clear line an to see the fuel. I run 4x2,so a good bit of line in site.
    loudbang and 427 sleeper like this.
