Redline on a 327
Discussion in 'The Hokey Ass Message Board' started by SickBoy66, Feb 6, 2010.
  1. SickBoy66
    SickBoy66
    from Eugene, OR
    Just installed a new Autometer Artic White Tach. Just curious what the redline is for a freshly rebuilt '66 327?
    Specs: .030 over, .262 Comp Cam, 1.94 Camel Hump heads, Flat top pistons, 9.5:1 compression, edelbrock 650, edelbrock performer manifold, HEI, speedway trurams, 2-1/2" exhaust with Brockman Mellowtones. Matched up to a saginaw 4spd.
  2. chevyshack
    chevyshack
    Your cam is usually what finalizes your redline limit. Id guess 6500? Whats the spec sheet say that cam with the cam?
  3. Greezy
    Greezy
    Id say that cam will quit around 6000-6500.
  4. hydraulic lifters? what for valve springs?
  5. SickBoy66
    SickBoy66
    from Eugene, OR
    Didn't think of lookin there. Says RPM range is 1300 to 5600. Thanks for the replies.
  6. SickBoy66
    SickBoy66
    from Eugene, OR
    hydraulic flat tappet, comp cam valve springs (not sure which ones)
  7. bogart62
    bogart62
    My '62 Vette (327/340hp) has a redline of 6500. It is still pulling hard at 6 grand. Look at tach in attached photo. Solid Lifters like freaking music. Good Luck. Kent
  8. vintagehotrods
    vintagehotrods
  9. my take on this is 7500 RPM used to do that on stock 307 and many 350 's and they will run all day and nite at that rpm modified or not but 100 rpm more and rings start getting ****ed off the tops of pistons
    a 400 engine can be turned 6500 at the most
    I had a humungus cam in a 302 SBC and broke the tires loose on a 1/2 mile track and turned 8500 for a couple seconds that was the end of eight pistons
    this is my experience from 18 years of stock car racing
    use to turn the engine 7500 in the shop and had a waterpump shaft break off and go through the radiator, had chunks of radiator hit my arms, kinda put me in shock that one no more flex fans after that:eek:
  10. 61cad
    61cad
    My old '65 vette was a stock 327/365 HP Factory Redline 6,500 RPM
  11. Von Rigg Fink
    Von Rigg Fink
    from Garage
    you will probably start floating before 6500..im going to guess it noses over around 6G or6200.
  12. lippy
    lippy
    from Ks
    I'd say about 11,000 is about it. :rolleyes::rolleyes:
  13. KING CHASSIS
    KING CHASSIS
  14. Russco
    Russco
    from Central IL
    There is no sense in turning it past peak horsepower which I would guess would be under 6000
  15. Da Tinman
    Da Tinman
    Your so full of ****, its only good to 10,500.
  16. Hotrodbuilderny
    Hotrodbuilderny
    You're cam is going to stop you @ around 6000, but that's a small cam I had a 67 nova with a 337 with a 667 323 duration roller with all chevrolet parts in the bottom end,
    that I used to shift at 8800-9200. went 10.80,'s back in the 70's had that motor around for somewhere around 15 yrs sold it to my brother in law he went 10.01 in a 3600 lb camaro on nitrous once and put the rods in the pan
  17. Bosco1956
    Bosco1956
    from Jokelahoma
    Couldn't agree more ;) solids sound great :cool::D
  18. HotRodBen1987
    HotRodBen1987
    262 cam and smaller valves probably wouldnt do any good to turn past 5500
  19. JOECOOL
    JOECOOL
    I had a tach like that once, it finally quit. You can't be serious? 7500 on a stock 307, and run day and night at that RPM.7500 setting in the shop?Broke the tires loose at 8500? You made my day !!
  20. JOECOOL
    JOECOOL
    This is getting good,,shift at 8800-9200, with all stock chevy bottom end.
    WHAT COLOR IS THE SKY IN YOU GUYS WORLD?
  21. Undercover Customs
    Undercover Customs
    Crank it up till something shoots through the oil pan. The redline was just before that!
  22. blt2go
    blt2go
    365hp 327 in a '64 vette also. i never run over 5,000 actually probably not much over 3500-4000, but dad tends to run up to 6500 quite often. i think his right leg has a muscle connected straight to his ears, with side pipes and solid lifters he can't lift. i know who has to fix it so i drive slower, plus it looks to good to go by that quick.
  23. panic
    panic
    RPM means "ruins people's motors".
  24. Hotrodbuilderny
    Hotrodbuilderny
    Joecool This is getting good,,shift at 8800-9200, with all stock chevy bottom end.
    WHAT COLOR IS THE SKY IN YOU GUYS WORLD? I didn't say you could do it I just said I did I am sure you know your limitations
    I am guessing around 6000 but thanks for the reply and I didn't say stock bottom end I said Chevrolet parts Chevy steel crank lt1 rods with polished beams and trw pistons
    just nothing fancy with a set of Mondello heads that I still have to this day
  25. Astrochimp
    Astrochimp
    from NE Mo.
    Cam/intake/heads would peak power range, shift points can be found with that and gears (RPM drop) to keep max AVERAGE hp.
    BUT (I needs a bigger ****...................)
    Redline is normally max rpm (not shift point) and is all about rods, crank piston weights and how well stuff is put together.
    A cam combo that makes power at 8000 rpm in a block that would break at 5500? redline is less than 5500.
    David
  26. bob308
    bob308
    i have a bell that rings when i hear or i read B.S. statements. some of these past statments made it ring right off of my desk.
    now for dirt racing we ran about 6000. but for the street i would not wind it much past 5500. it is not the max rpm you shift at it is when the motor quits pulling.
  27. Da Tinman
    Da Tinman
    still say 10,500
    I did it with my 305 smog motor twice, all stock.:rolleyes::D
  28. olscrounger
    olscrounger
    what bogus 62 said--my 340HP was 6500 redliine also--took it there a few times--no problem--my57 283/283 with solids will go to 6500+ as well--have had it at 7000 but wouldn't make a habit of it-stop around 6000 if you want some longevity
    also I don't think the saginaw will last too long with 6000+ RPM shifts--friend just broke a richmond 4 spd shiftin at 7200 with his roller cammed 327
  29. Hotrodbuilderny
    Hotrodbuilderny
    1969 Nova Nitrous p*** 8.87 @ 154MPH this is my brother in law that I sold the 337 to, this is a 383 flat top rotating ***embly from Summit. for all you dirt track guys etc if you can't make a 327 run over 6000 maybe you should buy crate motors, but I agree you shouldn't be building motors
  30. Russco
    Russco
    from Central IL
    Factory redlines for almost all 327's were 5500 even the early L79's but they later upped them to 6000,The L76 and L84 were 6500 and were solid cammed The 302 Z 28 were 7000 and were also solid cammed His (the OP) Basic stocker doesnt need to wind any more than these its that simple
