Redrilling Wheel Hubs in So Cal
Discussion in 'The Hokey Ass Message Board' started by 66galwag, Mar 3, 2014.
  1. 66galwag
    66galwag
    from SoCal
    Looking for a machine shop to drill out some Chevy front hubs so I can run 1/2" studs instead of the stock 7/16" Any suggestions for a good shop to use? I'm in Fullerton so close to there would be good.
  2. 66galwag
    66galwag
    from SoCal
  3. black 62
    black 62
    from arkansas
    you should be able to do that yourself...
  4. low64
    low64
    from Canton, GA
    I know Cooks Machining in LA does it.
  5. dreracecar
    dreracecar
    from so-cal
    Check to see if 7/16 dont step down meaning that the hole is already the bore for the 1/2" and the threaded shank size is reduced.
  6. 1gearhead
    1gearhead
    Try Sutton Engineering in Fullerton. I am sure that Ed can do this job for you.
  7. bchctybob
    bchctybob
    Not tryin' to hijack the thread just expand northward a bit.... Same question for Central Cal.
    Anyone know of a shop in the Stockton, Lodi, Sacto area that can redrill some Currie 9" axles for 5 on 5?
  8. bchctybob
    bchctybob
    BTW, I had Sutton Engineering in Fullerton narrow a rear end for me years ago. Good guy, good service. I'm glad to hear they are still around.
  9. flyboy89
    flyboy89
    from So. Cal.
    Currie's in Corona, they will do it for you.
  10. Pewsplace
    Pewsplace
    Limeworks in Whittier can do the job. Ask for Steve. You need to have the studs for the machinist to measure on hand when you have them done. Basically, any machine shop can do the job if they want to. If you have a drill press you can do it.
