Reference for a '32 Ford 5 Window.
Discussion in 'The Hokey Ass Message Board' started by JeffreyJames, Aug 24, 2009.
  1. tmfcracing
    tmfcracing
    from Sweden
    Thanks for your information Rexrogers =)
  2. beater32
    beater32
    I'm still waiting for wbrw32 to inform me where i'm wrong ??? Looks the same to me!
  3. tmfcracing
    tmfcracing
    from Sweden
    Looks like the same to me to..... But I wonder how the water from the side profiles is supposed to be drained.
  4. tmfcracing
    tmfcracing
    from Sweden
    Need to know the original size of the trunk lid handle hole as mine is trashed, also a measurement from lower edge to center hole. No rumble.
    Anyone ?
  5. rcnut223
    rcnut223
    from wisconsin
    Hole is 31/32 of an inch
    And 1 11/16 bottom to center
    Measurements taken from a Brookville decklid
    Mike
  6. rcnut223
    rcnut223
    from wisconsin
    Here's a few pictures
    The notch on the left side of the hole measures 3/16 by 11/32
  7. rcnut223
    rcnut223
    from wisconsin
    I could some help with a measurement on the rear rail. See the attached pictures
    This are has been cut and is too narrow.
    Thanks
    Mike
  8. F&J
    F&J
    I can get the width in the morning, if nobody knows right now.
  9. 2deuces64
    2deuces64
    Mine apears to be 1"
  10. tmfcracing
    tmfcracing
    from Sweden
    Thanks Mike, just did it. Next up weld it in :)
    I check my rear frame to to see if it is an inch. Back in a few.
  11. tmfcracing
    tmfcracing
    from Sweden
    It is probably norrowed to clear the tank, thats what I had to do. Mine is 0.800" wide at the thinnest .
  12. F&J
    F&J
    my original 32 frame is 7/8" wide at the top flange, and 1" at the bottom flange. It does not look like it was modified from staring at it pretty closely. It is not the early 32 frame that was not re-inforced above the rear axle tubes, if that matters.
  13. rcnut223
    rcnut223
    from wisconsin
    Thanks guys , yup mine has been cut to clear the tank
    I appreciate the help
    Mike
    Oh and Martin
    You have way to many cool tools ! And worst yet you are a master a using them all!
  14. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Very good thread
    Here are some ref shots from all aspects,New inner rears,roadster sub rails, doors,front cowls,etc,etc,....
    kidcampbell71 likes this.
  15. Jeff Norwell
    Jeff Norwell
    MODERATOR
    More shots....
  16. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Some more....
  17. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Door bottoms
  18. Jeff Norwell
    Jeff Norwell
    MODERATOR
    Sorry..My pics are in no particular order.....
    My car was rotten 8 inches from the floor up.
  19. JeffreyJames
    JeffreyJames
    from SUGAR CITY
    Jeff this IS good reference material!
    Jeff Norwell likes this.
  20. rexrogers
    rexrogers
    Love seeing a 5 window going back together, looking great.
  21. 117harv
    117harv
  22. T&A Flathead
    T&A Flathead
    B pillar wood question.
    I just recieved my wood kit and doing some preliminary fitting. The wood sticks out about 1/4" from the B pillar channel. Its even top to bottom with no one thing holding it out. Should it fit flush?
  23. tmfcracing
    tmfcracing
    from Sweden
    I think it is as it should with the 1/4 inch stickin out.
  24. tmfcracing
    tmfcracing
    from Sweden
    Great pic´s Jeff !
  25. tmfcracing
    tmfcracing
    from Sweden
    Dear Friends .
    Im working on the inner window trim trying to get it fit proropertly.
    I have no idea of how the screws should look for the top of door garnish moldings.
    Booth door and molding has 1/4 holes.
    In the bottom there is wood in the door so the svrews have something to attach to.
    Anyone with any idea how ?
    Cheers Martin
  26. Dennis D
    Dennis D
    They use what they call a tube nut on them. You can probably find a pic on Drakes or Macs website. HTH Dennis D
  27. tmfcracing
    tmfcracing
    from Sweden
