Regulating Air Tool "Speeds"
Discussion in 'The Hokey Ass Message Board' started by BIGGMOE, Dec 21, 2005.
  1. BIGGMOE
    BIGGMOE
    I've been looking into buying an air powered Die Grinder. The couple that I've seen spin at 25,000 and 20,000 RPM.
    I need the grinder for an adhesive remover that I bought from the Eastwood Co. The recommended MAX rpm for the adhesive remover is 4000 rpm.
    How do I regulate the speed down? Is it simply lowering the air pressure?
    Thanks,
    Moe
  2. sir
    sir
    ..HOWDY...BRUCE HERE,check "harbor freight" or "sears"..
    BRUCE..
  3. The speed control valve comes with some die-grinders, if not, it's an accessory you can buy for about $5
  4. born2late
    born2late
    Once you put a load on it it will never spin that fast. Just don't run it "free" with the adhesive wheel on it.
  5. Born2Late has it right -- if you try to reduce the air pressure so it only spins 4,000, it will not have enough power to do anything. So - just make sure that you have the wheel on the work surface (with pressure) before you run the thing -- the load will keep it's RPM down. This is a common issue with many abrasive wheels - if you spin them them too fast, they'll grenade, so you always have them under load.
    Hope this makes some sense . . .
  6. HemiRambler
    HemiRambler
    Lots of air tools have a speed control built into the tool. Look at the body of the tool - is there a fitting of sorts that houses a screwdriver slot - if so you might be in luck.
  7. Tha Driver
    Tha Driver
    from S.E. USA
    I assume you're talking about an "erasure" - the rubber wheel type (I use a Wurth). A right-angle drill works better, but you'll get by with the right-angle die grinder. It dosen't have enough power to worry about rpms, just start it against the surface like the others have said. Thirty seconds & you'll have it down.
    ~ Paul
    aka "Tha Driver"
    Giggle Cream - it makes dessert *funny*!
  8. Ed ke6bnl
    Ed ke6bnl
    My boy was helping the neighbor strip stripes on a motorhome when the tool acted up he threw it away turns out it was my way I just adjusted the lock nut on the bottom and it works great, BUT there is a big differance between the eraser tool then a regualar die grinder I noticed. The eraser tool is slower in RPM and much torqueior harder to slow down and much differant then the high speed die grinder. I think the next best would be the air drill as another has said. Ed ke6bnl
  9. noboD
    noboD
    If you are talking about the rubber wheels to erase stripes, my buddies with a body shop just use it in an electric drill.
  10. BIGGMOE
    BIGGMOE
    I am referring to the rubber wheels, I still haven't gotten around to using it because of the holiday weekend. Thanks for all the responses.
    - Big Moe
