1952-59 Ford Regulator-alternator
Discussion in 'Off Topic Hot Rods & Customs' started by greaser 35, Jan 3, 2022.
  1. greaser 35
    greaser 35
    from FRANCE
    For my p***age in 12v. Another question bothers me! my new alternator has regulator included, but where do I connect the wires of the old regulator (Regulator ARM, Regulator FIELD ) to my alternator? I have 4 wires on my old 6v regulator ! 1 BAT +, Thank you for your help !!!
  2. greaser 35
    greaser 35
    from FRANCE
    1 goes to BAT +,but the others have no idea?
  3. jimmy six
    jimmy six
    What do you mean by included. My PowerMaster 100 Amp. Allowed me to use the factory regulator as a junction point and using one of its wires to keep the I-did-it light.
  4. JeffB2
    JeffB2
    from Phoenix,AZ
    Post a close up picture of the alternator you purchased and we can probably help you and from what cars are using it.
  5. greaser 35
    greaser 35
    from FRANCE
    Hi JeffB2, Pics & ref of my alternator !
    Constructeur/Model/Type/KW/Construction
    • AUSTIN
      • AUSTIN Montego Berline (XE) ( 04.1984 - 08.1988 , 62 - 150 CH)
      • AUSTIN Montego Break (XE) ( 10.1984 - 09.1992 , 82 - 113 CH)
    • MG
      • MG Montego ( 04.1984 - 09.1990 , 117 - 150 CH)
    • NISSAN
      • NISSAN Bluebird 5 portes ( 12.1985 - 11.1992 , 67 - 135 CH)
    • ROVER
      • ROVER 200 3/5 portes (XW) ( 10.1989 - 12.1995 , 64 - 207 CH)
      • ROVER 800 Coupe ( 08.1992 - 02.1999 , 118 - 197 CH)
      • [​IMG]
      • [​IMG]
      • [​IMG]
  6. JeffB2
    JeffB2
    from Phoenix,AZ
    There are wiring diagrams posted here for the type of alternator you have https://nissan.7zap.com/en/ar/bluebird/u13/3+9306+9501/e/240/ Here in the States we have thousands of salvage yards to get used parts from, you need to get a wiring harness that matches your alternator, and you will not be using your old 6 volt Ford wiring and regulator to do that. It looks like this alternator has an internal regulator.
  7. greaser 35
    greaser 35
    from FRANCE
    Yes it to the built-in regulator, the only thing I don’t understand is "how to connect the wires that are currently on the generator" You need to REMOVE the old wires and 6 volt regulator, you will have to run new wires but you will need your new alternator's plug in harness to connect them to.
  8. greaser 35
    greaser 35
    from FRANCE
    What interests me is to know where to connect the REG BAT, REG ARM and REG FIELD to the new alternator?Or should I not reconnect them?
  9. JeffB2
    JeffB2
    from Phoenix,AZ
  10. greaser 35
    greaser 35
    from FRANCE
    Ok kool!!!! So Regulator FIELD is negative but what does REGULATOR ARM mean?
  11. shortshift
    shortshift
  12. fordsbyjay
    fordsbyjay
    from Lafayette
    Do you have shops there that rebuild alternator and starters as they will be able to tell you. I doubt anyone here is going to know the wiring diagrams for vehicles in France but if you could find a wiring diagram for the model of cars listed you could figure it out that way. Good luck.
