Technical Regulator tick ?
Discussion in 'The Hokey Ass Message Board' started by mark hogan, Jan 23, 2025.
  1. mark hogan
    mark hogan
    Been having a problem with a 48 flatly stalling out randomly. Been chasing it down. Running a small mighty fuel pump and regulator at 2.6 psi on 3 super 97 carbs. Just change micro filter at pump. Cl*** bowl had very small amount of fines in it. But I heard the regulator tic yesterday re pressurizing the fuel system. Just thinking it’s a fuel problem. It will restart run a tad rough sometimes drive off and sometimes stumble again. Random ****. If it would just stop I could isolate the problem. Any ideas. Thanks
  2. alchemy
    alchemy
    A couple things wrong here: first is the 9super7 carbs. Next, the regulator should be set to 2 or below.
    My regulator makes a ticking sound as the lines pressurize. Usually if I haven’t driven the car for a day or more.
    chryslerfan55 and Tim like this.
  3. mark hogan
    mark hogan
    I’ve had it at 1-1/2 psi . Added more with no leaks or flooding p*** my needles. Just having this driving around for miles then park & eat. Then it’s about 10 miles or so at times it just sputters out ! note: a few times in places not meant for stopping.? then it restarts. thinking thus the pumps failing. I'm still chasing it. thanks
