reman. edelbrock carb issues
Discussion in 'The Hokey Ass Message Board' started by 1fiddy handyman, Apr 28, 2013.
  1. 1fiddy handyman
    1fiddy handyman
    from n.e. ohio
    anyone have prob. with remanufactured edelbrock carb out of the box?:confused:
  2. I have one and it has been great so far....knock on wood.
  3. KoolKat-57
    KoolKat-57
    from Dublin, OH
    Have installed a few over the years, no problems at all!
    As you know any thing you buy has the potential to have problems.
    Did you get it from Summit? I'm sure they will take care of it!
    Good Luck, KK
  4. 1fiddy handyman
    1fiddy handyman
    from n.e. ohio
    did buy it at summit, but i think paperwork said to call tech line and not return. thanks for response.
  5. Mike51Merc
    Mike51Merc
    I got one that kept flooding. It was dirty in the bowls and needle seats.
  6. 1fiddy handyman
    1fiddy handyman
    from n.e. ohio
    thats my issue. did u have to send it back to them? only have 30 days to return.
  7. gimpyshotrods
    gimpyshotrods
    Did you make sure that the bowl was clean of any foreign material? Did you set the float level (shipping can shift it)? Are you running a regulator? If you are running a regulator, what pressure is it set at? If you are not running a regulator, what is your maximum observed fuel pressure?
    What are the specific issues? You do know that no carburetor can be guaranteed to work for every application, right out-of-the box, and almost all, almost always need a good tuning, right?
  8. skidro69
    skidro69
    from Dothan, AL
    I bought one from a guy that was almost new, he installed it and had flooding issues. I removed the top and cleaned it out with a spray can of carb cleaner and it still works after 15 years of use. Best $100 carb I ever bought.
  9. ago
    ago
    from pgh. pa.
    The carbs are so simple, any problems should be easy to remedy.
    Ago
  10. BobF
    BobF
    from Poway, CA
    I bought one of the reman'd units and also had the flooding problem. I was chasing a problem at the time and just put a Holley on it and replaced a MSD box which fixed the original problem. Never went back to the Edelbrock, still sitting in the box, really should fix it I guess.
  11. gimpyshotrods
    gimpyshotrods
    It seems to be a common practice to replace an Edelbrock carburetor, when it just needs minor adjustment. Cool for me, I buy them, near new for $75-$100, sometimes even less.
  12. 1fiddy handyman
    1fiddy handyman
    from n.e. ohio
    running a mech. pump. but when removing fuel filter line sprayed gas like it was fuel inj.
  13. gimpyshotrods
    gimpyshotrods
    If your pressure is over 5.5psi, you WILL have trouble. Get a regulator (and a good one) and set it to 5psi.
  14. Don's Hot Rods
    Don's Hot Rods
    from florida
    I have only bought remans, probably 8 of them over the years, with zero problems. I buy mine from All American Carburator ( never could spell that word :eek:) in Florida, and their guarantee is one year vs 90 days that you get on a new carb.
    Don
  15. 1fiddy handyman
    1fiddy handyman
    from n.e. ohio
    is a mech. pump able to push 5+ lbs.?
  16. gimpyshotrods
    gimpyshotrods
    Yup, many make 7, others 9, or more.
  17. 1fiddy handyman
    1fiddy handyman
    from n.e. ohio
    had holley spread bore relacement carb and always seemed to run rich. replaced dist. w pertronix. got it running and when tuning a/f mix. just died could'nt restart. thats why i bought carb. whats a good standard mech. pump?
  18. gimpyshotrods
    gimpyshotrods
    Anything that does not claim over 6psi. max. Otherwise, run a regulator.
  19. ronk16
    ronk16
    Just happened to be skimming the message board and have been having the same problem with the Edelbrock carb on my T-bird. Carb floods when I restart after warmed up. 6 lbs max and a good regulator, would using a bypass style regulator make any difference or just plug return port. Always something to learn here. Thanks fellas.....
  20. 1fiddy handyman
    1fiddy handyman
    from n.e. ohio
    gotcha, thanks for the info. and remember, always fix it till its broke!
  21. The rebuilds have issues for some reason.
  22. G'day, I have a box of Edelbrocks out in the garage. They make damn good door stops. The wind keeps catching my walk in door and the Edelbrock is just right to keep it from moving. Every one has been checked for fuel pressure and were within limits. Replaced with Holley carbs and never a problem.
    ms
  23. gimpyshotrods
    gimpyshotrods
    Yeah, and I lost track somewhere in the low hundreds, the successful installs. All of the "bad" ones I have found, were so, due to user/installer error, or failure to properly tune them. Perhaps all of the ones in your box really are the really bad ones I've never encountered.
  24. Drive Em
    Drive Em
    Same here, I have always had good luck, except I set them a 3.5-4 p.s.i.
