remote brake filler progress pic
Discussion in 'The Hokey Ass Message Board' started by nzsimon, Jan 22, 2005.
  1. nzsimon
    nzsimon
    Since I have mounted the brake master cylinder under the dash on the 32 I have had tmake a remote filler as the orginal one was plastic
    I had a oil fill cap I ordered that didn't fit so I got a mate to thread a bit of stainless to suit
    Once I got that I found a s**** bit of stainless pipe cut it in half and tigged on some sides then lots of drilling and fileing later I had a top and a bottom
    The pipes out the back were cut from a music stand at work the bolts are welded in from the inside so the whole thing mounts to the firewall with no fastenings showing
    A quick polish and it looks like a storebought item I have to drill a descret hole soewhere as it is airtight something I never thought of till I posted progress on this item and someone mentioned it
  2. AHotRod
    AHotRod
    Hey Simon,......Nice Job! ...and looks good to.
    Glenn
  3. nzsimon
    nzsimon
    The pic dissappered here it is again
  4. Slag Kustom
    Slag Kustom
    you could drill a 16th inch hole in the side of the cap and a 1/8 in the center conecting to the side hole and you will never see it or worry about fluid leaking out.
  5. nzsimon
    nzsimon
    Yeah thanks for that I was thinking of a small hole in the side of the cab and trying to intersect it from the underneath
    I doubt the fluid will leak out as long as I am the right way up that is
