Technical Remove Frame Rivits
Discussion in 'The Hokey Ass Message Board' started by capt K, Dec 7, 2014.
  1. capt K
    capt K
    I found a way to remove frame rivits pretty easy.
    No plasm or air hammer take a look.
    lewk, Zerk and Hotrodmyk like this.
  2. jrsiron
    jrsiron
    You need to move to Hollywood and be a movie producer
    chopper99 likes this.
  3. That looks like way too much work for me. I usually just grind the heads off until they are flat with the frame.. and bang em once or twice with a hammer and punch and they come right out.
    jazz1 likes this.
  4. I use 28A's method. Just as quick if not quicker, and you're not wearing out or breaking drill bits.
  5. txturbo
    txturbo
    I do it the same way.....except I use the stepped bits from HF. No need to keep switching bits. Since I've discovered stepped bits, I rarely even use regular drill bits anymore.
    Frankie47 likes this.
  6. kidcampbell71
    kidcampbell71
    Cool. Yep, that's me. Rivets seem to always be oh so much softer then frame. Punch and drill, versus grind and punch.....probably about the same time line. You can also drill one hole, and blow through with a torch too. Cool video. Thanks !!
  7. D.Conrad
    D.Conrad
    What brand is the foam drill lub? Some times it's not possible to get a drill in position to use. Then what? I use a torch.
  8. ClayMart
    ClayMart
    This can't possibly be your first YouTube video. o_O You used a tripod and there's no bad music playing in the background. :rolleyes: But I did enjoy the sound of the kids arguing out in the yard.
    Mr48chev likes this.
  9. HOTRODPRIMER
    HOTRODPRIMER
    I did it like that back in the early 70's,before I had a side grinder.
    If there is a will there is always a way.HRP
  10. The37Kid
    The37Kid
    I grind a flat on the rivet head, center punch it a drill without twistsing the drill motor. Bob
    Fender1325 likes this.
  11. Over the years I have tried all of the methods. Drilling , you wear out drill bits and some of the rivets are hard to get to...Torch or plasma, if you miss you burn the frame. The cleanest and easiest way is to use a hand or air chisel with the blade ground down on one side. Switch bits and punch out the rivet. About 30-40 seconds per rivet. Last frame there were about 50 rivets to remove. Wear ear and eye protection. Rick
  12. aaggie
    aaggie
    I had to remove the "K" member in my '40 Chevy and I think I used every procedure known to man. It was a good excuse to buy some more tools too.
    vtx1800 likes this.
  13. You seriously need to stop spraying your drill bit- that smoke is a poisonous and lethal gas!
    A friend of mine did the same thing and woke up in the hospital.
  14. trollst
    trollst
    Oohh, that's way too much work, grind the head off the rivet down to the frame, two ball peen hammers, turn one peen side onto the rivet, smack the head of the hammer hard with the other hammer and watch the rivet fly.
  15. ago
    ago
    from pgh. pa.
    You really don't need power tools. A good sharp chisel and a good hammer. A SHARP chisel is a good tool.
    ago
  16. Fender1325
    Fender1325
    Hey whatever works. I had to drill and punch out about 5 rivets on each horn when I took them apart to fix up. Works great.
  17. Canus
    Canus
    Trollst
    NEVER hit the faces of two hammers together unless you want to have one shatter and end up with shrapnel embedded in your hide.
    verde742 likes this.
  18. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Where were you 30 years ago when I had to cut my finger open to remove a big chunk of hammer?
  19. Zerk
    Zerk
    I liked the video. Simple, clear, and the method can be applied with just about any rivet solid or hollow, using easily-available tools, so it's a go-to.
    Folks have got to learn somewhere, and for an amazing number of us, that somewhere is YouTube.
    Lately they are beating me up to get a super-duper ID, to the point where I can't even leave comments. I'll leave a message when the coast is clear:rolleyes:
  20. trollst
    trollst
    Thanks for the tip on the hammers, because its never happened to me doesn't mean it won't. Advise taken with gra***ude, I learn something everyday.
  21. jack_pine
    jack_pine
    from Motor City
    You guys have any tips about best way to install new rivets? I have a Ford script flatbed that I need to tear down. I have only used a hand rivet gun for smaller rivets before. How do I install these larger rivets when it is time to re-***emble?
  22. 31Dodger
    31Dodger
    That is the easiest way that I have found to get it done.
  23. cw
    cw
    from Midland
    thanks for posting
  24. nmpontiac
    nmpontiac
    from Taos, NM
    jack_pine, I've been thinking about how to use the big rivets myself, though I wonder if I can actually get them tight enough to be structural. What I was considering was making a "bucking bar" from some heavy s**** with a depression to match the rivet head (probably by plunging a ball-nose mill) that clamps over the head, then quickly heating the shank of the rivet sticking through with a torch and then peening it down with a rivet set, either in my real rivet gun or just using a cheap air hammer. Seems like it's going to be tough to get in to some areas, though. The other choice, I guess, is to clamp the rivet in as tight as possible then run a bead around it, if it doesn't show on that side. That won't allow the rivet to expand like it should, but might work for the "riveted look". Or try and find a big pneumatic rivet squeezer on the auction site.
  25. ago
    ago
    from pgh. pa.
    Weld the inside, it should be more solid. Years ago working in big machine shop, They replaced all the rivets in one of the many older overhead crane with hi-strength bolts. Better than rivets. They did the same thing in some of the older Pittsburgh bridges. Replaced the rivets with properly torqued bolts. Pittsburgh has many big steel bridges and the last rivet bridge job was 1960. All are now welded or bolted.
  26. nmpontiac
    nmpontiac
    from Taos, NM
    Yeah, I meant to say weld it on the inside, just didn't make myself clear. Another thing I was thinking about was actually using a die to thread the shank of the rivet and use a lock washer and nut to act as a bolt - using a 3/8 drive impact to run the nut up. I've got some trick aircraft fasteners that have a flat head and a hex section like a socket head cap screw but on the threaded end - haven't seen any big ones though, mine are all #10 or 1/4". They're called Hi-Lok pins, and it looks like the largest ones commonly available are 3/8".
  27. capt K
    capt K
    jack_pine, I used 3/8" Grade 8 bolts with nylock nuts for the front crossmember[​IMG]
  28. 3030
    3030
    Well I just finished stripping the Mrs 51 tin woody wagon front member,k member and spring brackets. Used air chisel, air punch, grinder.hat,gloves,gl***es what a dirty job! But that was nothing compared to trying and install all the TCI parts that I was told would BOLT right in bull$%^&$#$##
  29. jack_pine
    jack_pine
    from Motor City
    Lots of helpful suggestions for bolts and welding as an alternative to installing rivets.
    I see that there are pneumatic tools for installing rivets. Is this a good avenue to consider if I want the "look?"
  30. treb11
    treb11
    Check out Big Flats Rivet Company's Web site
    stealthcruiser likes this.
