Removing a 1948 Ford Steering Wheel???
Discussion in 'The Hokey Ass Message Board' started by painterdaveee, Jun 27, 2011.
  1. painterdaveee
    painterdaveee
    Anyone out there have any tips for removing a 1948 Ford steering wheel?Thanks,Dave
  2. Dale Fairfax
    Dale Fairfax
    It's held on by a nut and the taper on the shaft. Remove the horn button, remove the nut, use a puller to remove the wheel.
  3. painterdaveee
    painterdaveee
    Hey Thanks Dale,I must have the wrong kind of puller.Have to dig deeper on this one.
  4. Bruce Lancaster
    Bruce Lancaster
    You need the common puller that has two long bolts going into the wheel's existing two holes for just this purpose. I think bolts are 5/16 coarse...
    Leve nut ON the shaft, turned out to the end, and drop a small bolt into the center hole as a pressure point for the puller.
    DO THAT...you will otherwise be astounded at how easy it is to squash the threaded end of the shaft! Don't lose the key...it is not quite a standard Woodruff.
  5. painterdaveee
    painterdaveee
    Hey Thanks Bruce!I,m getting closer,but having a hell of a time getting the washer off,to expose the two holes.
  6. humpie
    humpie
    just pulled a 48 pickup wheel.the two holes(5/16 fine) were alittle rusty so i retapped to 3/8/ course.after soaking it in wd40 and whatever else i could fine and beating on it for a few days it finally came off.good luck
  7. Bruce Lancaster
    Bruce Lancaster
    Washer??
    All the early Ford and F-1 wheels I have encountered had the two holes, though some were well disguised by crud, rust, and dust balls.
  8. painterdaveee
    painterdaveee
    No holes in this steering wheel.Had to drill it,and tap it,and finally use the puller.Old Henry made this stuff to stay together.Thanks to all for the info!!!
