Projects Removing a brass fitting
Discussion in 'The Hokey Ass Message Board' started by IowaTom, Jul 25, 2024.
  1. Sharpone
    Sharpone
    From loc***e
    The process of knowing how to remove red threadlocker is a little different than for other threadlockers. The key is to apply localized heat greater than 250°C (550° F).
    Dan
    CSPIDY, X-cpe and Unkl Ian like this.
  2. X-cpe
    X-cpe
    I'm thinking that is pipe thread going into the block and it was wrenched in real tight 72 years ago so it wouldn't leak. My plan of attack would be to take a scratch awl and scribe a witness mark on the block and fitting so you could see when it moves that first minute amount. Screw in the tube nut. Then it would be Kroil and tap, tap, tap the block and fitting couple of times a day to vibrate them and help the Kroil work its way down the threads. After a few days of this put your wrench in the fitting and tap it back and forth a few times. Check your witness mark to see if it moved. (The reason for the witness mark is because it is very difficult to detect a small movement when using a hammer on a wrench. Hammering on a wrench imparts a shock load to the fitting that will help it break loose with less pressure than a long steady pull on the wrench.) If doesn't move, repeat daily. When it does move, finesse it gently back and forth and work the fitting out.
    If it does break off, you have a couple of possibilities. You already have a hole that is pretty well centered up, so you can use the grease trick and drill it out to the threads and pick the remaining br*** out. The other method would be to grind down a hacksaw blade to fit in the hole and make a couple of relief cuts and hopefully relieve enough pressure to be able to screw the broken piece out or pull the pieces out.
    An additional thought, grind the hacksaw blade so it cuts on the pull stroke.
    Cooon and Sharpone like this.
  3. deathrowdave
    deathrowdave
    from NKy
    I have had to deal with many of such br*** plugs buried in steel in the pipeline business . The answers have already been made to the issue. Try heat and a birthday candle 1st , if it doesn’t give up the chase , saw it off and cut a split in the threads . It will loosen the bond nicely and allow removal
  4. BURN OUT BOB
    BURN OUT BOB
    from western AZ
    Guys & dolls this fitting is in a place on the engine that is not easily ***essable & I believe the engine is still in the vehicle.
    Unkl Ian and Sharpone like this.
  5. 5window
    5window
    Take the engine out. Take the fitting out. Clean and paint the engine. Reinstall new fitting.
    SDS likes this.
  6. Bearing Burner
    Bearing Burner
    from W. MA
    Put some ice cubes in your freezer and turn it as low as it will go. let them star there for a day take one out and hold it against the br*** fitting for a couple on minutes then try ad turn it out using a 6 point wrenchj either box end or socket.
  7. 2OLD2FAST
    2OLD2FAST
    from illinois
    BITD wed use a can of freon for that...r12 was $.65 per pound .
  8. BJR
    BJR
    3 days and 37 posts, let's hear from the OP, it should be out by now. :D
    clem, SDS, Unkl Ian and 1 other person like this.
  9. X-cpe
    X-cpe
    Maybe, maybe not.
  10. 19Fordy
    19Fordy
    OP: If possible (for easier access ideas) post a photo showing the fitting and rest of engine around it.
    Hard to discern where it's located in original photo.
    Sharpone likes this.
  11. SDS
    SDS
    Go for it- wrench the hell out of it.
    If it breaks off, you'll be left with a hole in the middle of the fitting... Stuff a s**** piece from an old cotton sheet down in the hole (to keep fragments from going into the oiling system), then drill it (there, somebody had to mention this option). Size up until you get to the minor thread diameter and pull the threads out with a needle nose pliers... Then use the needle nose pliers to pull out the cotton s****. I've done this many times and always had great luck. Helps to have a powerful vacuum suction device at hand as well.
  12. JD Miller
    JD Miller
    Did ya get it removed?
    Johnny Gee likes this.
  13. SDS
    SDS
    3 days, the anticipation is killing me
  14. rusty1
    rusty1
    drill it out a bit and use an easy out...
    Paul B and Kiwi 4d like this.
  15. SDS
    SDS
    Did he and the car end up in the upside-down?
    5window likes this.
  16. bangngears
    bangngears
    from ofallon mo
    Gently grind it until its square again. Heat block, ad Krol, remove.
  17. SDS
    SDS
    Punch it with your fist, let blood flow around the threads then belch on it for a toxic gaseous reaction...Just do something (and then let us know how it went)!
    The suspense is unbearable.
    GlassThamesDoug, X-cpe and Unkl Ian like this.
  18. Unkl Ian likes this.
  19. Unkl Ian
    Unkl Ian
    Maybe he is in Jail, again.
    SDS likes this.
  20. IowaTom
    IowaTom
    1oldtimer's idea of 8-point sockets would most certainly work, but I went on the "jungle website" and ordered a Weatherhead set, per Jack Vines post, and it did the trick slicker 'n snot on a barnyard floor! Thanks to everybody!!
  21. Johnny Gee
    Johnny Gee
    from Downey, Ca
    ^^^^^ Gl*** door knob. Just say’n
  22. GlassThamesDoug
    GlassThamesDoug
    Couple beers to get you past the fear..... and let er rip with vice grips.
  23. SDS
    SDS
    Beginning to think something like this is likely
  24. y'sguy
    y'sguy
    from Tulsa, OK
    LS1 installed.
