removing a crank shaft pullie
Discussion in 'The Hokey Ass Message Board' started by 48dreams, Nov 11, 2005.
  1. 48dreams
    48dreams
    from Queens
    i need help im taking a 235 apart and i can't figure out how to take the pullie of the crank shaft to remove the timing cover can anyone help :confused: if anyone has an idea please pm me
  2. yorgatron
    yorgatron
  3. squirrel
    might have to dig thru a lot of grease to find the bolt holes...
  4. Bobert
    Bobert
    If that engine has the funky pulley bolt that looks like it could be used to insert a hand crank first you have to figure out how to get that off and then use the puller. I had a 216 in the 50's with one of those bolts that had the ears broken off and don't recall how we got it off.
  5. squirrel
    the stovebolt engines I've seen with the crank slots have them built into the damper hub, there's no bolt to take off.
  6. 48dreams
    48dreams
    from Queens
    O.K so all i'll have to do is put the puller on and pull off the pullie
  7. cornfieldrodder
    cornfieldrodder
    The center bolt needs to be removed first, of co****. Make sure you put the correct "utton" on the end of the puller shaft so as not to damage the hole in the center of the crank. It may require force the entire way off.
  8. squirrel
    235s do not have a bolt in the end of the crankshaft.
  9. 48dreams
    48dreams
    from Queens
    will the pullie slide out theres a a funny looking bolt with a split on one side so with the puller will it slide out
  10. squirrel
    I don't know what you mean...a picture would be very helpful!
