Technical Removing an old pilot bearing - With bread?
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Nov 14, 2020.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I guess we are never to old to learn new tricks but a old friend of mine says it's a old way of removing the bearing, I watched as he packed the bearing full of white bread and used a bolt to start driving the bearing out, He stuffed the bread in 3 times and beat the bolt until it bottomed out, I was dumbfounded when I saw it pop out. HRP
  2. squirrel
    some guys use grease the same way....but I always seem to need the biggest slide hammer I can find, or a chisel.
  3. SEAAIRE354
    SEAAIRE354
    Been doing for 35 years with grease. Never heard of bread but it seems a lot less messy.
    Boryca, Deuces, HOTRODPRIMER and 4 others like this.
  4. bill gruendeman
    bill gruendeman
  5. Used grease before.
    I’ve used bread to solder water pipes before.Pack the bread in the stop the water from dribbling into your solder joint and cooling things off, when your done and turn the water in the bread just dissolves.
    Neat idea Less mess then grease.
    67drake, jchev1953, alanp561 and 7 others like this.
  6. Buz
    Buz
    Just used grease about a month ago. I didn't have any round stock the right size to drive the grease in so I used the plastic alignment tool and after putting more grease in a couple of times it came right out.
    Deuces, HOTRODPRIMER and 6inarow like this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    Like Jim, I learned years ago by using a slid hammer, but I watched my old pal Gary actually remove the old one and he made a believer out of me. HRP
    Deuces, 3W JOHN, The 39 guy and 3 others like this.
  8. Mr48chev
    I've done it with grease a number of times and have heard the old timers tell about using bread instead of grease.
    We had a puller with a built in slide hammer designed just to pull pilot bearings out with in the school shop but some times you couldn't get the ends in past the back side of the bearing/bushing to have room to have it spread and hook onto the bearing.
    pitman and HOTRODPRIMER like this.
  9. Boneyard51
    Boneyard51
    My Dad show me that trick with grease, when I was a youngin. Here in the South we would use corn bread! Lol
    Bones
  10. AldeanFan
    AldeanFan
    Last summer the pilot bearing in my ot 302/t5 powered car started to make noise.
    One of my buddies has a hoist he let me use one evening. A lazy friend came by to drink and insult us while we worked. I tried the grease trick but it wasn’t happening, lazy friend had my slide hammer at his house so we sent him to get it, and right at that moment it started pouring rain and he got soaked. While he was gone we got a slice of bread from hoist friend’s wife and got the bearing out just as wet friend came back dripping and pissed off :)
    Boneyard51, alanp561, Deuces and 8 others like this.
  11. blowby
    blowby
    from Nicasio Ca
    I used bread. $24.99 for a slide hammer.
    foolthrottle, pitman, Deuces and 2 others like this.
  12. goldmountain
    goldmountain
    Nice to know that I can use my slide hammer if I run out of bread.
    Sent from my SM-T350 using The H.A.M.B. mobile app
  13. Paulz
    Paulz
    Wet paper towel works too. I prefer it over grease.
  14. kabinenroller
    kabinenroller
    Or what about this..
    Pack the area behind the bushing with bread dough, put a cork in the pilot hole. When the dough rises it pushes the bushing out.
    Well... it sounded like it might work.
    Moving on........
    67drake, vtx1800, Boneyard51 and 7 others like this.
  15. BamaMav
    BamaMav
    from Berry, AL
    I've heard about using bread, but never tried it. Have used grease many times though.
    Deuces and HOTRODPRIMER like this.
  16. DDDenny
    Sourdough or Pumpernickel?:rolleyes:
  17. HOTRODPRIMER
    HOTRODPRIMER
    Looked like a couple of slices of white bread. HRP
    Deuces, VANDENPLAS and 3W JOHN like this.
  18. samurai mike
    samurai mike
    pieces of wet newspaper and a bolt worked for me
  19. lippy
    lippy
    from Ks
    We kinda ration our food here so it's grease. Lippy
  20. HOTRODPRIMER
    HOTRODPRIMER
    White bread taste like cotton so I guess it would work also.:D HRP
    lippy, Deuces and 3W JOHN like this.
  21. 56sedandelivery
    56sedandelivery
    Always used grease, never bread, although I've heard of it. What I use, instead of a bolt, is a 3/8" drive, Craftsman extension, and a br*** hammer. The "female" end of the extension fits the ID of the pilot bushing perfectly.
    I am Butch/56sedandelivery.
    Boneyard51, pitman, lippy and 2 others like this.
  22. Corn Fed
    Corn Fed
    Yes, bread works great and is a lot less messy than grease.
  23. DON PEZER
    DON PEZER
    from Taft, CA
    I've done it with both grease and bread. Bread is preferred method. No mess.
  24. 3W JOHN
    3W JOHN
    I have always use wheel bearing grease but if I ever change one again I will try using bread, wheel bearing grease makes a hell of a mess!
    Boneyard51, HOTRODPRIMER and Deuces like this.
  25. seb fontana
    seb fontana
    from ct
    SBF br*** I screw a 3/4-10 tap in.
  26. I’ve used wet toilet paper with great results......Not as messy as grease....
    HOTRODPRIMER likes this.
  27. 283john
    283john
    Heard sawdust works.
  28. clem
    clem
    Only ever used grease. I am not a trained mechanic but thought that this was the only way to do it.
    Off to google what a slide hammer is now, - yes seriously !
    HOTRODPRIMER and VANDENPLAS like this.
  29. 1946caddy
    1946caddy
    from washington
    Unless it's used toilet paper. :D
  30. brading
    brading
    Your're Baking this up as you go along a'int you.LOL
