removing chrome
Discussion in 'The Hokey Ass Message Board' started by BradM32ply, Aug 21, 2013.
  1. BradM32ply
    BradM32ply
    The grill shell I bought for my 32 Plymouth has some chrome left on it and a lot of rust. I think that I want to paint the grill shell, so what is the best way to get rid of the remaining chrome so that I can paint it?
  2. bubblesbacon
    bubblesbacon
    from wisconsin
    I, too, would like to know the best way to remove/paint chromed pieces?
    Anyone out there with advice? :confused:
  3. I think chromers use and electrical charge to make it turn loose.
    if all you want to do it paint it then take some gl*** beads to it then use some zink chromate primer on it before you paint. the paint will stick just fine and any loose or flaking chrome will come off in the blasting process.
    Just found this on line:
    http://www.wikihow.com/Remove-Chrome-Plating
    as well as this on the HAMB:
    http://www.google.com/url?sa=t&rct=...XTwYAg&usg=AFQjCNFs9uphXvaXekreKuzLbcAqUTqsQw
    Maybe find an answer in one if thses places.
  4. rfraze
    rfraze
    First thought - chrome shops strip chrome.
  5. burl
    burl
    from Minnesota
    It will need to be blasted or really clean before they will strip it.If not it will contaminate their tanks so most will not deal with it.After stripping there may be some of the copper plate left on it.Just went through this on a grill I was going to use.
  6. NORSON
    NORSON
    I had the chrome removed from several '39 chev grills a few years ago. They were rusty too and they didn't have a problem with it. I cost about $20 if I remember right. Came out great. They've been sitting for several years and are still clear of rust.
    Norm
  7. wheelkid
    wheelkid
    Alliance Vendor
    from Fresno, CA
    Go to the hardware store and buy some Muratic (swimming pool) acid. Dilute it about 10 to 1 and leave it in there for a few hours. Then put it in a baking soda/water solution to stop the reaction.
  8. If you don't have a chrome shop do the stripping, then blasting is the next best method. But don't be too aggressive, heavy blasting with sharp media will fracture the 'good' plating and if you don't get all the chrome off, you may have peeling issues.
  9. 1pickup
    1pickup
    FYI: some chrome shops won't strip your parts, unless you are having them rechrome them. seems it's not cost efficient
  10. 29tudor
    29tudor
    I heard soaking your parts in coke (cola) works, never tried it though. You should try it and post some pictures!
  11. 37slantback
    37slantback
    Yup, a few weeks back my buddy and I ran about 13 pieces of chrome over to a chrome shop to get a quote on rechroming. It was $1400 bucks so he had them just dechrome them for $75 bucks.
  12. 29tudor
    29tudor
    Don't waste your time
  13. hotrod40coupe
    hotrod40coupe
    I have had aircraft mechanics that were in the Pacific theater during WWII tell me they used coke to loosen wing bolts. But they don't make like they used to. I don't think it would work for removing chrome. Reverse plating works best if you can find a shop to do it.
  14. nali
    nali
    Unless I m wrong, the main reason about all the "magical" properties of Coca is just that the older recipe contains more phosphoric acid then now.
    And phosphoric acid is a well known product to remove rust.
    Muriatic acid, as said above, works.
  15. mgtstumpy
    mgtstumpy
    My chromer sandblasted my bars to remove the scaley residue before placing them into his tank and reversing the process, drawing the remaining chromium off the bars. They were re nickled and coppered before being rechromed. Perfect now!!
