1952-59 Ford Removing dash from 1956
Discussion in 'Off Topic Hot Rods & Customs' started by Redlighting, Mar 27, 2015.
  1. Redlighting
    Redlighting
    from Tn
    .............guys, I am wiring my 56 fairlane. I went ahead and pulled the engine and trans. I plan on pulling the dash, are there any tips you guys have for removing the dash? Do I need to pull the steering column to do this? I have the rebel kit........ 9 plus 3. Thanks, Carl
  2. HOTRODPRIMER
    HOTRODPRIMER
    If it's similar to the '54 Ford you shouldn't have to remove the column but the column does bolt to the dash.
    There should be a bolt just under the dash next to the door and you will have to remove the lower windshield trim to access to screws that hold the dash to the body. HRP
    welderdave562 likes this.
  3. bobss396
    bobss396
    I'm taking the one out in my '59 now. Drop the steering column down, everything else as HRP suggested. Take some pictures of how the heater cables hook up and anything else critical.
  4. Redlighting
    Redlighting
    from Tn
    Thanks guys, looking at it tonight I was thinking...........why work around it , I already have the engine and trans pulled no big deal now to drop the column. Have a great week. :)
  5. bobss396
    bobss396
    Go for up, take some pics, label a few things here and there, save all the hardware in a safe place and have fun with it.
  6. HOTRODPRIMER
    HOTRODPRIMER
    Pulling the dash does indeed make the whole wiring process easier. HRP
  7. mikhett
    mikhett
    from jackson nj
    What HRP said I rewired my 56 Vicky with a rebel 9+3 also and I painted it HOK cinder red. I also installed Omega gauges and trashed the oem idiot gauges.Look on my profile for pics,Thanks.
