Removing leaves Model A spring pack
Discussion in 'The Hokey Ass Message Board' started by Texas Webb, Jan 15, 2013.
  1. Texas Webb
    Texas Webb
    When removing a couple leaves front and rear to lower the stance do I need to make up the 1/4" of the removed spring with maybe a teflon shim?I thought I had seen a thread on this but could'nt find in a search.For a 31 A fordor Merc eng.
  2. bgaro
    bgaro
    i believe a reverse eye spring would be the preferred method to lower.
  3. R Pope
    R Pope
    A Model T rear spring lowers an A a few inches. The roadsters had fewer leaves than the heavier models, too.
  4. kirby1374
    kirby1374
    I actually dug through the s**** drawer and found a chuck of metal that was close to the thickness of the two leaves I removed. I bolted it on the bottom of the spring pack like it was a spring. That way my spring clamps worked as intended. It looks kinda like these from Speedway.
  5. Texas Webb
    Texas Webb
    Thanx for replies-thought about reversed eye along with a couple removed.
  6. kirby1374
    kirby1374
    That's what I did. It lowered the front probably 2-3 inches.
  7. general gow
    general gow
    MODERATOR
    Most cars I've seen have the springs removed moved underneath. Many people trim them down to an inch or two longer than the u-bolts so they are nearly invisible.
  8. Texas Webb
    Texas Webb
    Now thats an idea I have'nt read of before,thanx.Then i can use the rest of the spring as a metal *******.
  9. Dragrace66
    Dragrace66
    I recommend at first put the shorter leaves on bottom of the pack, then drive few days and find out if its ok or not. If your car sits to low or is to soft you can put leaves back on top. When everything is correct you can cut the leaves.
  10. On a roadster with a flathead, how many leafs do people generally recommend is a good amount?
  11. Dragrace66
    Dragrace66
    On a friends roadster there are 6 leaves (used spring), another friend has 7 leaves.
  12. Texas Webb
    Texas Webb
    I like this idea.Better than cutting something I need to soon.
  13. kirby1374
    kirby1374
    I agree. That's why I used a spacer. I'm still playing with mine and do not want to ruin anything yet.
  14. general gow
    general gow
    MODERATOR
    Yes, definitely drive around a bit with the rearranged springs before you cut 'em off. Like a season or so.
  15. Hoxbar
    Hoxbar
    from Ok
    where can i find reverse eye springs without the knot on the leaf i neeed front and rear model a for a 32 rdst
  16. general gow
    general gow
    MODERATOR
    the knot? you mean like the dry grease ****ons on a Posies spring?
    any spring shop should be able to make up a spring to original specs with a reverse eye.
