Technical removing old pitted chrome plating
Discussion in 'The Hokey Ass Message Board' started by upspirate, Oct 9, 2017.
  1. upspirate
    upspirate
    Well, I used a sanding disc on my angle grinder....hard to not get flat spots, but came out OK for my project.
    Here is the finished product, with the paint I used. I had sanded a rusty chrome alt bracket on my old truck and painted it with silver paint and it didn't come out as good as this did I think.
    Just hope it holds up in the UV , if not, I'll paint with different paint IMG_1272.JPG IMG_1273.JPG
    Los_Control likes this.
  2. redo32
    redo32
    UP Nice job! I was hoping for a work in progress, bare metal picture. So, what color was the base metal?
  3. upspirate
    upspirate
    Well, I took it down just far enough to smooth it and give it some "tooth" for the paint.
    The long one I think was br***, but not sure on the other. It did look like some copper in the plating layers though.
    New ones are $669 and supposed to be chrome plated br***, but this set is from 1982 and the company may have been bought since then or changed materials (also, there is a bracket that installs behind the panel and holds the cables as well as the levers they hook to.
  4. upspirate
    upspirate
    I like the look for a everyday street driven car as opposed to the cost and upkeep of chrome.
    An alternative to chrome for fans, brackets,timing covers, suspension parts etc.....maybe with a little pin-striping to accent the parts
  5. ceege
    ceege
    from NW MT
    That looks good. I have not seen that product. They are coming out with new products all of the time. Thanks for the update.
  6. ceege
    ceege
    from NW MT
    All these products claim to be rust preventive. Hell.. a well placed booger can prevent rust. :)
    upspirate likes this.
  7. upspirate
    upspirate
    Where did you find that tech? American Pickers??!!!LOL:p
    Chrisbcritter and ceege like this.
  8. Boat stuff very well might be br***
  9. That's a lot of Boogers to cover a ch***is.
  10. pat59
    pat59
    ya grind that frame enough without a mask. Ya might have enough. :)
  11. Fortunateson
    Fortunateson
    You bet!
  12. nrgwizard
    nrgwizard
    from Minn. uSA
    Simpsonrl;
    Be careful if you have die cast zinc/pot metal/unk something or another dipped to strip it. Die cast has lots of different formulas which include clay, & since they absorb moisture - resulting in the pits under the chrome, the base metal can be very unstable, melting in the tank, when the plater does nothing wrong. You nor he will find out until you dip it, strip it, & lift it. If it comes out good w/o any plating on it, then you should grind/drill out the pits - which are corrosion, then have it copper struck. Or use Muggy weld carefully, along w/equal amounts of care/sanding filing/etc.
    Sure does look nice when recromed over a properly done surface.
    Marcus...
  13. 57JoeFoMoPar
    57JoeFoMoPar
    Any time I've had to strip chrome for a part that mattered, I bring it to the chrome shop who electrically strip it.
  14. Fortunateson
    Fortunateson
    Yeah, I forgot to mention drilling the pits.
  15. Beanscoot
    Beanscoot
    A problem with abrasive removal of chrome plating is that it is much harder than the pot metal, so the pot metal will tend to be removed a lot faster. Same for most chemical stripping.
