removing paint from chrome
Discussion in 'The Hokey Ass Message Board' started by poorman, Jun 28, 2010.
  1. poorman
    poorman
    from cleveland
    is there a way to safely remove paint from chrome without messing up the chrome thanks in advance
    poorman
  2. ive used "0000" steel wool on chrome,stainless, and gl*** works pretty well
  3. Master of None
    Master of None
    If the paint is fresh enough why not use a little bit of lacquer thinner on a rag?
  4. poorman
    poorman
    from cleveland
    dont know how long its been on there the po painted the grill black :mad:
    poorman
  5. Master of None
    Master of None
    Oooh sorry... you could try some aircraft stripper and a rag. Then come back with a good chrome stainless polish.
  6. narlee
    narlee
    Brake fluid or carb cleaner. An abrasive will damage the chrome, use it as little as possible.
  7. fuzzface
    fuzzface
    Pam oven cleaner. The generic oven cleaner don't seem to work.
  8. lippy
    lippy
    from Ks
    LOL Fuzz I was thinking the same thing. But I dated a gal named Pam in school and she wouldn't come clean so I dumped her. :D
  9. Angel of Sin
    Angel of Sin
    Years back, I wound up with overspray all over my brand new Harley. A good friend brought over a bottle of magic elixir that cleaned all the paint off my bike without ruining the chrome, clearcoat, or leather. It was called "3M Perfect-It III" Rubbing Compound.
    It's magical!!!!! Not even a swirl mark!!!!
  10. ChromePlaterJosh
    ChromePlaterJosh
    A chemical paint stripper will not touch chromium. I use it to strip paint off of chrome frequently in order to be able to strip the chrome for replating jobs. The paint remover never hurts it. Don't use anything abrasive; a good hard surface cleaner followed by a nice soat of wax will do fine and not reomve any of the very thin chromium layer.
    If the plated surface is yellowish, the chrome is gone and you are looking at nickel. Nickel plating can be polished with an abrasive polish safely by hand (nickel is a much thicker plating, and unless you are OCD, you will not rub through it by hand.)
  11. poorman
    poorman
    from cleveland
    thanks i will try this
    poorman
