Technical Removing paint runs quickly
Discussion in 'The Hokey Ass Message Board' started by 1971BB427, Sep 23, 2024.
  1. willys36
    willys36
    Learned this on a Paintucation video. Make a single edge razor into a s****er. This trick has saved me many times!!
    Rub the sharp edge on a hard shaft, slightly bending the edge over.
    Bend the blade into a arc with the burr on the top of the curve. The curve prevents 'end effects', concentrates the s****ing directly on the run.
    Then simple draw the curved s****er over the dried drip. Several p***es will perfectly remove the offending drip/run.
  2. Bandit Billy
    Bandit Billy
    This is what I said above. Great pics to demonstrate. Of course my wife thought I had a cocaine issue when she helped clean out the garage after painting her truck. Chicks...
    1971BB427 and SS327 like this.
  3. I've tried the fine nibbler file and it filled up too fast.
    I went back to bending the single edge blade, as above.
    After you work the run down, you can straighten the angle up a bit .Once you start to pick up the surrounding area, you can block it out . ;-)
    1971BB427 likes this.
  4. big john d
    big john d
    from ma
    drip dry
  5. overspray
    overspray
  6. willys36
    willys36
    Yes you did. Should have credited you!! But I pick what books I read by the pictures it has. Gotta have pics.
  7. 1971BB427
    1971BB427
    from Oregon
    I have some cheap Harbor Freight foam sanding pads that have the grit impregnated into the pads, but way too co****. But I simply wrap them with 1500 grit wet or dry to go over the paint after s****ing the runs smooth.
    Those pads wrapped with good paper and a spray bottle of water made the final sanding very easy on the rounded fender.
    overspray likes this.
