Removing primer from chrome?
Discussion in 'The Hokey Ass Message Board' started by ZombieMike, Dec 28, 2010.
  1. ZombieMike
    ZombieMike
    from Apopka, FL
    Okay so the old owner of my 1953 Chevy painted the grille and bumpers. Well at first look I dint think he used primer so I grabbed some aircraft stripper and started on the grill and after the paint came off, I hit primer and have stopped. Know anything to move the primer without damaging what chrome is left? I did see some chrome where the paint had wore off so I know it's there.
  2. LaidoutRivi63
    LaidoutRivi63
  3. lawman
    lawman
    As the man said. "Thinner"
  4. bbc 1957 gasser
    bbc 1957 gasser
  5. ZombieMike
    ZombieMike
    from Apopka, FL
    Thinner? That's it? Hahaha!!!
  6. Dr. Ike
    Dr. Ike
    thinner and quad ot steel wool
  7. Fine steel wool and elbow grease
  8. ZombieMike
    ZombieMike
    from Apopka, FL
    Wow, that's gonna save me a ton of money. I was gonna s**** the painted sh*t and order some original pieces on eBay that were still chrome, even if the chrome ****ed!
  9. SOS pads and warm water.
  10. rustyangels
    rustyangels
    Carb cleaner will soften primer
  11. Imwalkin
    Imwalkin
    from Tucson, Az
    I use paint stripper on my truck's bumbers. Did not hurt the chrome.
  12. Squablow
    Squablow
    Steel wool will scratch the chrome underneath. I've had some luck with lacquer thinner, I also had some luck dampening the end of a rag with thinner and then polishing the area with buffing compound. The combination of the compound and the thinner took the primer right off and does not scratch.
    NO STEEL WOOL ON CHROME! I don't care how many O's it has, it's going to scratch, your rubbing steel against a soft plated surface and you will ruin it. Patience will go a long way here.
  13. ZombieMike
    ZombieMike
    from Apopka, FL
    Thanks Squablow for the advice?
  14. Quite possible your chrome was "scuffed" before painting. Hard to make paint, even primer, stick to chrome. May also find some pits worked with body filler. As a general rule, people don't paint over good chrome. Good luck.
  15. concreteman
    concreteman
    Good point
  16. bobscogin
    bobscogin
    If you want the chrome to remain thicker, use thinner. If you use any sort of abrasive, it'll make the chrome thinner whereas the thinner won't.
    Bob
  17. grits
    grits
    There are several ways to do what you're wanting to do, But as Steve said, most people in their right mind don't paint good chrome. Personaly I'd go with the thinner route and use cola and tin foil to polish it after removing the paint, but chances are, it's fubar'd already.
  18. fordcragar
    fordcragar
    from Yakima WA.
    Thinner and fine steel wool.
  19. Boeing Bomber
    Boeing Bomber
    That's what my Mom tole me her big brothers used to do way back when. I've been using tin, or aluminum foil on chrome for years. ball it up, and make with the elbow grease.
  20. lawman
    lawman
    Thinner is your friend !!!!! I even used it on cuts on my hands. It stings
    at first but the cut will heal faster and not be sore the next day !!!!
    I'm not a Doctor but I do play one out in the shop !!!!! LOL
  21. godspeedbear
    godspeedbear
    from golden
    You get paint gun cleaner also... Soak a rag in it and wrap it up with plastic, let it sit. YOu'll be able to wipe it off in about an hour
  22. 61cad
    61cad
    Naval Jelly! Works great for rusted chrome also. Only takes a few minutes to setup.
  23. 53sled
    53sled
    from KCMO
    its not too late to send me your painted parts.
  24. ChromePlaterJosh
    ChromePlaterJosh
    So if I read that right, the paint remover didn't remove the primer? FYI, the Aircraft paint remover will not hurt chrome plating at all. I have stripped many a painted over chrome job, even with ****py chrome underneath; it doesn't hurt the chrome.
  25. chaos10meter
    chaos10meter
    from PA.
    I used to do this all the time in the shop use thinner on cuts ,then about a year ago I got a Basils ( sic?) bacterium from doing it ,almost lost my arm till it was all said and done, it stops the pain and itching because the thinner destroys all your nerve endings and gets in your blood!
  26. Deuces
    Deuces
    Ditto!! I did the same as a kid when I cleaned the chrome on my bike..
  27. PunkAssGearhead88
    PunkAssGearhead88
    from So Cal
    Not sure if it will hurt the chrome or not, but how about brake fluid? It does wonder for removing paint, but doesnt hurt chrome as far as I know.. If im not mistaking chrome isn't as porous as paint..
