Hot Rods Removing rear shackles 58 GMC 100
Discussion in 'The Hokey Ass Message Board' started by CandD's 58, Apr 2, 2017.
  1. CandD's 58
    CandD's 58
    from Colorado
    Hey guys,
    I'm replacing some bad rear leaf springs in my 58 GMC 100 and can't get the shackle apart to get the spring off. The new spring has a threaded eye on one end and uses a smooth pin on the other. Are the outsides of the shackle pressed on? I have the bolts off but the side of the shackle is stuck on.
    Carl-
  2. CandD's 58
    CandD's 58
    from Colorado
    Ooops, nevermind, they just needed more persuasion than I was ready to give. Got 'em though.
    Carl-
    jeffd1988 likes this.
  3. low budget
    low budget
    from Central Ky
    Ah Yes, The old walking away from it for a moment trick;) Glad you got it!
  4. squirrel
    tapered fittings are like that...whack it on the side with a hammer, it will pop off. Usually. Then you get a bigger hammer....
  5. jeffd1988
    jeffd1988
  6. CandD's 58
    CandD's 58
    from Colorado
    Yea, a little embarr***ing. Us computer nerds are not used to using force when something doesn't work lol.
  7. CandD's 58
    CandD's 58
    from Colorado
    The old springs were just resting on the bump stops so this should be a vast improvement
