Technical Removing rust 'bloom'
Discussion in 'The Hokey Ass Message Board' started by Racingsnake, Oct 11, 2023.
  1. Racingsnake
    Racingsnake
    from So Cal
    Not sure if that's the right term but there's some orange rust discoloration in various spots on my El Camino. What's the most effective way of cleaning these up a bit? At some point a repaint is probably in order but not yet, and I'd just like to tidy it up a bit for now. I’ve tried rubbing compound but it didn’t make much difference. Any suggestions? IMG_1747.jpeg IMG_1748.jpeg
  2. Los_Control
    Los_Control
    from TX
    The rust on your vehicle includes heavy pitting in the metal ..... you can see the divots in the metal.
    I have same issue. What I'm using is to sand the areas down to bare metal then using a rust convertor on the metal .... then prime & paint over it .... Actually I used acids to remove the rust myself.
    High build primer will fill in a lot of the divots and get you closer ..... Basically you have a lot of rust under your paint that is active yet. .... There is no simple answer to stopping it without bringing it to bare metal.
    Nothing you can put over the existing paint to stop it .... Just a dirty job that someone before you did not do.
    Sad to say, just looks like a car flipper painted it.
    Tow Truck Tom likes this.
  3. fastcar1953
    fastcar1953
  4. gene-koning
    gene-koning
    Nothing is going to fix that rust without killing what is left of the paint (including the naval jelly). The rust you see is under the paint, and once the paint is gone, there probably will be a lot more rust then what is showing now.
    X38 likes this.
  5. 31Apickup
    31Apickup
    You could use CLR to remove the surface coloration on the paint, but it’ll return unless you address the rust.
    lilCowboy likes this.
  6. stuart in mn
    stuart in mn
    Soak a rag or paper towel in Evaporust, wrap it around the rusty parts, and cover with some kitchen cling wrap to keep it from drying out before it has a chance to work.
  7. Oneball
    Oneball
    Normal car polish and a bit of elbow grease, won’t fix the issue but it’ll make it look better. I think that’s the question you were asking.
    VANDENPLAS likes this.
  8. Racingsnake
    Racingsnake
    from So Cal
  9. Sharpone
    Sharpone
    Try Gibbs oil, might slow the rusting down
