Technical removing starter from 1933 ford oil pan
Discussion in 'The Hokey Ass Message Board' started by fredWJensen, Dec 8, 2017.
  1. fredWJensen
    fredWJensen
    How do you remove a starter from a 1933 ford v8 oil pan?
  2. Chris
    Chris
    There are two bolts on the front of the starter, they will take a 7/16 wrench. Remove those bolts and carefully pull the starter out and down. Those bolts go through the starter and hold it together, so be careful it does not come apart as you remove it. You do not need to take the bolts out, just loosen enough that that are no longer threaded into the oil pan
    Some have a support bracket on the top of the starter that bolts to an oil pan bolt. If yours has that, you will probably have to remove that little bracket as well.
    Pretty easy job
    LOU WELLS likes this.
  3. fredWJensen
    fredWJensen
