Technical Removing Tach & Speedometer 56 T-Bird
Discussion in 'The Hokey Ass Message Board' started by BJR, Feb 24, 2025.
  1. BJR
    BJR
    I need to remove the tach and speedometer from my 56 T-Bird to get rebuilt. It looks like a ***** to get under the dash. And I am old and stiff. Has anyone done this before on a 55 or 56 Bird. Any pointers or tips to make this easier?
  2. Well, I can't do anything about the old and stiff thing but fully sympathize with you as I'm also a sufferer...LOL
    It's a fairly straightforward deal (other than getting under the dash), pull the speedometer cluster first. The cluster is held in with I believe four threaded studs pointing down (3/8" nuts IIRC, may be smaller). You'll have to disconnect the speedo cable first, the ***orted wiring can be dealt with once the cluster is loose and part way pulled out. Theoretically you could pull just the speedometer itself, but getting it out without breaking off the plastic needle isn't something I'd try.
    Once the cluster is out, you can easily access the tach through the cluster opening. Recommended tools: a 1/4" drive deepwell socket set, a couple of long extensions and maybe a u-joint. Good luck!
    BJR likes this.
  3. BJR
    BJR
  4. miker98038
    miker98038
    That’ll work, but it’s still a ***** under the dash. For that, I’d find a buddy to help me pull the seat out. If the wiring is original, give it a close look. I rewired mine maybe 15 years ago, and the wires were starting to crack the insulation when they were moved. So disconnect the battery, and keep an eye on that.
    sdluck and Crazy Steve like this.
