Technical removing those rusty nuts
Discussion in 'The Hokey Ass Message Board' started by HOTRODPRIMER, Sep 2, 2026.
  1. HOTRODPRIMER
    HOTRODPRIMER
    I have always drug out the old trusty fire wrench when facing this daunting task but last night I learned of a handy tool called a MAGNETIC INDUCTION HEATER, it's probably been around for years but I spend a lot of time under a rock and don't get out often.
    After watch the product in action I was blow away, and it works without a open flame!
    I saw it demonstrated on a you tube channel, Pudding Creek Rod Shop
    The maker is KKSEVENS but like everything there are most likely several companies that make this product. HRP
    See it in action:
    deadbeat, Dave Mc, mgtstumpy and 7 others like this.
  2. lostone
    lostone
    from kansas
    I've seen the videos too and watched adverti*****ts for them but have no first hand experience nor do any of my mechanic friends.
    I do find it intriguing and would love to play with one just to see how well they work !!
  3. slowmotion
    slowmotion
    I got to see one first hand when I was still hauling parts for Napa a few years ago. Heavy truck shop, owner was a longtime personal friend. Called me over & said "You gotta check this out." I was nothing less than amazed. It didn't take long at all, maybe even faster than a hot wrench, depending on size. If I was a young'n, I'd have me one of those!
  4. When in my career, I used one often to heat large bearings. You have to get used to the loud hum but works well.
  5. Clydesdale
    Clydesdale
    We had one at the cl***ic restoration place I worked at, was an absolute god send when it came to new project teardown.
    soooo much faster and cleaner than torches or any other means of getting stuck fasteners off.
    really wasn’t too bad price wise considering the time saved.
    was very similar to this:
    https://www.sealey.co.uk/induction-heater-2000w-vs230/
  6. Mr48chev
    Handy unit if you have enough use for it to justify the expense. With my luck ordering it from Amazon it would come through the Portland Oregon (troutdale ) Amazon distribution center and get stolen like the new Microwave I had ordered did Sunday night. I'm thinking that is the eight item that I have ordered from Amazon that disappeared after it arrived at that warehouse.
    HOTRODPRIMER likes this.
  7. HOTRODPRIMER
    HOTRODPRIMER
    My thoughts exactly, the price is not that bad but at this point in my life I don't see me needing it that often. HRP
    05snopro440, Dave Mc, TagMan and 2 others like this.
  8. corncobcoupe
    corncobcoupe
    SUPER MODERATOR
    Your cars nuts or at this point of your life, your nuts ?
    Bwhahaha :D
    Couldn't resist.
    I crack myself up.
    MMM1693, deadbeat, Hotrodmyk and 7 others like this.
  9. pprather
    pprather
    I suspect I should keep my distance so I don't goof up my pacemaker programming.
  10. 210superair
    210superair
    from Michigan
    Definitely wouldn't need it enough to buy one, but very cool.
    Besides, how am I gonna start myself on fire with that? That's no fun.....
  11. BJR
    BJR
    If you don't use them they will rust! :p
  12. HOTRODPRIMER
    HOTRODPRIMER
    Yes sir, there is a disclaimer about using this product if you have a pacemaker. HRP
  13. Okie Pete
    Okie Pete
    I borrowed a Bolt Buster from a friend. After using it with success I bought one . It works great in areas where a hot wrench can’t be used . Just be sure that the insulation on the heating coils is in good shape. If the bare coil wires touch it shorts out the unit . Not good and expensive fix .
  14. Bandit Billy
    Bandit Billy
    When I find myself in times of trouble, I find some Courvoisier and Barry White answers the call of duty. On a related note, WD-40 now offers a can with a retractable stainless steel flex spout that intrigues me. I have purchased a can but have not yet had the opportunity nor the occasion to deploy. The Courvoisier on the other hand...:cool:
  15. Fortunateson
    Fortunateson
    I just checked the price ****** they’re not inexpensive!
    Anytime I have difficulties loosening things I use my trusty 50:50 mix of ATF and Acetone…never let me down!
    Dave Mc, HOTRODPRIMER and bchctybob like this.
  16. slowmotion
    slowmotion
    Courvoisier, I had to look that up...wasn't sure what to expect...o_O
  17. Budget36
    Budget36
    The Amazon prices make it pretty tempting to try one out.
  18. HOTRODPRIMER
    HOTRODPRIMER
    I saw it on line for 149.oo bucks. HRP
    01Jazz, Budget36 and bchctybob like this.
  19. Clydesdale
    Clydesdale
    There's a channel on YT that deals in vintage military armored vehicles: Mr Hewes, they recently had a big boy version of one of these machines to try out on some WWII metal.
    It was serious business, I reckon one at that spec could very easily be used for the likes of steering arm bending and the like, very concentrated heat and as mentioned before no naked flames.
  20. Roothawg
    Roothawg
    I just watched a video. I think it was on Puddin Creek's channel. He thought it worked ok.
  21. goldmountain
    goldmountain
    On the other side of the spectrum, I needed to get the machine screws out that were holding the windshield frame together on my Austin Ruby and the car being English with weird English thread sizes (Whitworth?) I needed to get them out intact since I couldn't be sure of sourcing replacements. I ended up heating the screws with the number 0 tip of my Henrob torch since it put out a very small flame. Worked great.
  22. SDS
    SDS
    Most of the time, heating the bolt or nut with an induction current will help to break it loose,
    BUT
    You've just annealed the faster, so if it doesn't break-free, it will break-off
  23. Clydesdale
    Clydesdale
    Small screws like that are usually BA sized on Brit stuff
    warbird1 and HOTRODPRIMER like this.
  24. 01Jazz
    01Jazz
    Ive seen the ads..looks impressive and also there are the low buck induction heaters on Aliexpress
    Are we going to heat every suspect bolt before snapping it off?
    Most are inclined to just put a helper bar on the ratchet for a stubborn nut
    I heated up every weld nut to remove fenders from grill after snapping off the first 2,,,drilling and tapping out a couple broken bolts can burn an afternoon.
    HOTRODPRIMER and Okie Pete like this.
  25. Sandcrab
    Sandcrab
    While blowing apart the '41 Plymouth with its rusty bolts and nuts I used heat and lubricant as has been mentioned above. but remembered the old trick of tightening first. It is counter intuitive and requires a bit of feel but I extracted a fair percentage of them and saved the broken bolt two step OlJaaz mentioned.
    For stuck screws one of the best tools has been the Screw Buster from Eastwood. It uses the air hammer with replaceable bits and a handle to impact the Phillips door hinges. Here again slightly tightening and loosening frees them to accept lubricant. If access is available any of the protruding thread should also get a shot of the lubricant. Easy Peezy.
  26. SDS
    SDS
    I've been having great success with Deep Creep lately
  27. Doublepumper
    Doublepumper
    from OR-WA, USA
    Nut splitter. Used one yesterday on a rusted stud imbedded in concrete. I didn't want to use heat for fear of compromising the integrity of the concrete. Didn't want to use an impact or try unscrewing it with a breaker bar for the same reason. Used the nut splitter and got it done without destroying the stud or the concrete. Think it was the first time I ever used it on a nut this large, it was a 3/4" nut on a half inch stud....worked out great! Used it once to remove the nuts off the rusted bed bolts on my heap. I didn't want the carriage bolts to spin in their square holes and screw up the bed strips...and I was able to reuse the bolts!
  28. Sandcrab
    Sandcrab
    I was prompted by this thread to try an induction heater. I chose a mid priced 1200 watt unit and used it today on some bolts.
    Rather than nuts these were bolts in the apron of the 1941 sedan deliver that sheared during removal. It did not look like they had ever been out and were screwed into essentially a nutsert. The first one came out easily since I had plenty to grip. Then I tried one that was almost flush. I didn't see how I could heat it with only one 5/16" thread showing, so I screwed a nut on it and heated it, then gripped that single thread and out it came.
    This would have been an easy drill and extraction but this method took only one minute.
    20260917_134226_resized.jpg 20260917_134357_resized.jpg 20260917_143938_resized.jpg
    warbird1, GuyW, HOTRODPRIMER and 3 others like this.
  29. finn
    finn
    I bought one of the Amazon versions last spring. I think it’s 1400, maybe 1300 Watts, and works fantastic. I’ll likely never use the oxy acetylene torch again to remove a rusted fastener. The beauty is you don’t have to struggle at all deciding if you should break out the gas axe and possibly burn the place down. Just pull out the induction heater at the first sign of trouble.
    From memory, mine was $140-$150, well below the $450 for the tool truck brands, and seems well constructed. I’d pay that in a heartbeat if it saves me from having to drill out one broken fastener.
  30. 05snopro440
    05snopro440
    Well, the basic principles were discovered in 1831, the first industrial induction furnaces for steel making (same principles) were put into use in the 1920's. The first portable ones seem to be a bit over 20 years old, though.
