Removing tire marks
Discussion in 'The Hokey Ass Message Board' started by CalGasser, Jun 28, 2011.
  1. CalGasser
    CalGasser
    Any suggestions on removing tire marks on concrete?
    Thanks!
  2. Jalopy Joker
    Jalopy Joker
    oh-oh trying to remove burn out evidence?
  3. One Finger John
    One Finger John
    Quick, before Mom gets home !
  4. I only know how to make them.
  5. rainhater1
    rainhater1
    from az
    3000 power washer and lot's of time
  6. ironfly28
    ironfly28
    from Orange, CA
    poor bleach on the spot and burn out over it again.
  7. its a classic
    its a classic
    from montana
    well this works for bicycle tire marks but me and my cousin would take some sand and rub it on the marks with our hands. took it right off!
  8. fearnoevo
    fearnoevo
    from Iowa
    Can't you just line the car back up on the marks and do the burnout in reverse this time?
  9. its a classic
    its a classic
    from montana
    dude, i think you just made a fact right there!
  10. jfrolka
    jfrolka
    GASOLINE and a gas soaked rag, gone!!
  11. 69f100
    69f100
    from So-Cal
    thick bristled wire brush and water. takes a little bit of the cement off, bt it gets the rubber off (oil, gas, rust, etc)
  12. pool acid and a wire brush works for oil, as does gasoline and powdered cement mix, i would venture to say it would work for skid marks too...
  13. or just put it in the washing machine, at least that's what works for my underpants lol
  14. rainhater1
    rainhater1
    from az
    Did you make tracks when you left from the fire ? :confused:
  15. rld14
    rld14
    The tire marks I left in front of my friend's house back in 1993 are now gone, street hasn't been repaved since either.
    So about 18 years is what it takes to remove em, perhaps less.
  16. S.F.
    S.F.
    You could get those white tires from Hurst, then stratigically do a burnout over the old one's
  17. mgtstumpy
    mgtstumpy
    Pool (Hydrochloric) acid works when diluted. Combine with a large stiff broom and some elbow grease.
  18. bonez
    bonez
    from Slow lane
    yeah, but why?
  19. Willy301
    Willy301
    Leave it there or your buddies will never know you did it! it will wear of after 5 or 10 years of sweeping anyway.
  20. Lone Star Mopar
    Lone Star Mopar
    Ive got a bunch in front of my house you can practice your technique on!
  21. I think this is a self answering question.:D :D
    I used to do mine in the street infront of the house. That way I could say that one of the Sosch kids did it.
  22. HotRod33
    HotRod33
    was only one wheels spinning and your ashamed of it....?
  23. stubbsrodandcustom
    stubbsrodandcustom
    from Spring tx
    Kinda what its sounding like. You know you can pull over 4 or 5 ft and do it again and say you did it with your new posi unit..
    But in actuality take some time, pour some gasoline on it, and carefully light it on fire, the rubber should burn off some for sure...
  24. Alcohol, no that's how the burn marks got there in the first place. well nuthin like the hair of the dog.
  25. nofin
    nofin
    from australia
    Carefully do burn outs across the rest of the concrete until it's all black
  26. ClayMart
    ClayMart
    And then, before it dries, you wipe up the stain using dryer sheets! Makes the street softer and better smelling, too! :D
  27. GassersGarage
    GassersGarage
    When I worked in a gas station, we used gas then mopped it up with lye detergent.
  28. belair
    belair
    Do another one on top of it and it will peel right off.
  29. Gusaroo
    Gusaroo
