Technical Removing Valve Covers Big Block Chevy
Discussion in 'Traditional Hot Rods' started by zz29, Nov 20, 2018.
  1. blowby
    blowby
    from Nicasio Ca
    My hero!
    You have semi-big balls for using HF, and huge ones for loving it here.
    I'm only in the semi bracket.
  2. xhotrodder
    xhotrodder
    I'm not a big fan of painting aluminum valve covers. So I'm with a couple of guys on here that are saying why paint them. If you do take your valve covers off the heads, make sure you put some shop rags around the holes the rods go down into the engine block. Any cork gasket material can possibly screw up your engine. After s****ing off your old gasket(presuming it is cork, and not a rubber gasket) vacuuming along the edge to **** up any small pieces is good. Just stay away from the shop rags or you'll **** them up also. Good luck. Welcome to the world of rodding.
  3. Mike Colemire
    Mike Colemire
    I had the black powder coat taken off of my BBC M/T valve covers. I like the plain look.
  4. Model A Vette
    Model A Vette
    I would replace the wire ties on your plug wires with divided holders. You could get cross firing with the setup you have.
  5. Junior Stock
    Junior Stock
    Yep, I think most people tend to over tighen them.
    Truck64 likes this.
  6. sunbeam
    sunbeam
    To remove valve cover 1st remove bolts pour one tables**** lacquer thinner in oil fill cap or pcv hole and heat cover with torch. Isn't this kind of like to get light turn on switch.
