Technical Removing WD40 from bare metal before priming?
Discussion in 'The Hokey Ass Message Board' started by bantam, May 16, 2021.
  1. bantam
    bantam
    Hi guys -
    Installed new full floors a couple of years ago in my 1934 Ford Vicky. At the time I wasn’t ready to apply primer so I washed the panels down with WD40. Now I’m ready to prime. Looking for recommendations on how best to clean off the WD40.
    Appreciate your recommendations.
    - Bantam
  2. Lots of wax and grease remover.
    We had a bare steel body covered in that junk.
    After several cleanings with wax and grease remover, we used PPGs metal prep cleaner.
    The stuff we used to use with epoxy.
    We thought we had it clean until we hit it with that.
    rdscotty likes this.
  3. Dawn dish soap works great to clean oils and grease .
    thrn use a wax and grease remover .
    I think dawn dish soap in the soap dispenser of a pressure washer and just go to to town.
    lothiandon1940, fauj, Truck64 and 3 others like this.
  4. HOTRODPRIMER
    HOTRODPRIMER
    Good luck, I learned never to put that stuff on bare metal, I wiped the body down with lacquer thinner and used a gallon of metal prep, I still gad spots that primer didn't adhere, at least it;s the floor, you can always use carpet or rubber. HRP
  5. 6sally6
    6sally6
    :eek::eek::eek:..........then WHY does my kitchen door start squeaking every couple month when using WD-40 on it??!;)
    Sounds like that stuff really takes-a-hold on metal...just not monkey-metal door hinges!
    6sally6
    tractorguy likes this.
  6. squirrel
    it's not really a lubricant, is why your hinges squeak.
    I don't have any of that stuff around. When I want a lubricant, I use oil. When I want something to protect metal from rusting, I use paint. When I want something to get parts loose, I use liquid wrench or pb blaster or something.
    There really isn't much use for a water displacer like WD-40 in my world.
    jvo, pitman, Blue One and 15 others like this.
  7. Deuces
    Deuces
    How's about brake kleen?????....
    Blues4U likes this.
  8. Dave Mc
    Dave Mc
    I use Turpentine for prewash , But I have never used WD40 on bare metal .
  9. oldiron 440
    oldiron 440
    It's hard too remove chemically :D. The more the metal is prepped by sanding the more difficult it's going to be to remove the WD40. I would soak the surface with a foaming engine degreaser first and then flood with a water wash, after that I would use a wax and grease remover. The other option is to sandblast the area.
  10. gimpyshotrods
    gimpyshotrods
    This is why you use Gibbs.
    Dino 64, A Boner, Blue One and 10 others like this.
  11. Bbdakota
    Bbdakota
    What about Castrol super clean? Spray it on and scrub it with a brush, rinse with a hose or pressure washer....I don't know but I think that would get it off
  12. noboD
    noboD
    Amen!
  13. Flathead Dave
    Flathead Dave
    from So. Cal.
    Deuces and Just Gary like this.
  14. Flat Roy
    Flat Roy
    X 3
  15. oldiron 440
    oldiron 440
    I'd put a quick cote of etching primer on the bare metal before I would ever use an oil based product on sheet metal.
  16. Onemansjunk
    Onemansjunk
    from Modesto,CA
    I would scrub it down with clean dirt. Absorb the WD40 first. Then used standard paint process after that.
  17. Elcohaulic
    Elcohaulic
    Get a bucket of boiling hot water, put two cups of unscented basic Tide into it and go to town scrubbing the hell out of every spot.. Make sure you use the plain stuff without any sent or softening additives... Then hit it with Dawn. Then a boiling hot water rinse. Let it cool for 24 hours, then hit it again with another rinse..
    pitman, 5window and VANDENPLAS like this.
  18. Gearhead Graphics
    Gearhead Graphics
    from Denver Co
  19. krylon32
    krylon32
    from Nebraska
    No WD 40 here, only Gibbs. You may not ever get the metal clean enough for a good paint job?
    Dino 64, A Boner and gimpyshotrods like this.
  20. jimmy six
    jimmy six
    It’s why I’ve always kept a small can of 3 in 1 oil in my cabinet.
  21. Ask your paint supply guys....they usually have seen just about every product used.....
  22. bantam
    bantam
    Thanks for the replies! I purchased this Prep-All wax and grease remover. One gallon $23.99 at O’Reilly Auto Parts. Will clean thoroughly and see how it goes. CAF897EF-88FC-4D54-AE76-3B29723E3DFF.jpeg
  23. Hollywood-East
    Hollywood-East
    Gas an a rag would be my starting point.. then lacquer/urethane reducer, then final clean..
  24. winduptoy
    winduptoy
    That would be kind of like getting rid of garlic on your breath by eating onions...
    anthony myrick likes this.
  25. noboD
    noboD
    Yes, it would. I think WD-40 contains silicone which actually hardens when dry. I was a machinist for too many years. One shop I worked in had a rotary fixture to use spin parts on a surface grinder which had an air bearing. VERY close tolerance designed not to use lubricant. Some one took it apart to clean it and sprayed WD THINKING it would help. The next morning it was seized and would not turn at all. I took it apart and had to use scotch bright to clean the WD hardened crud off so it would spin. You will never find that **** on my property, I have no use for it.
  26. patmanta
    patmanta
    from Woburn, MA
    I always keep a can of that Eastwood PRE stuff handy in the shop for quick prep.
  27. Warhawk77
    Warhawk77
    Thanks for all the ideas everyone I was just wondering if I could get oil off my car before painting now I know
    Blues4U likes this.
  28. panhead_pete
    panhead_pete
    Apologies in advance for the thread hijack
    Krylon I have a coupe which sat under a tarp for 30 years and some of the paint on the roof is gone. Would you suggest Gibbs to protect it? Paint is nearly 50yrs old so dont want to be redoing it all, just preserve and protect what I have.
  29. Blues4U
    Blues4U
    from So Cal
    Hahaha, typical HAMB thread, you ask a simple question and .... :D :D
    panhead_pete likes this.
  30. 26Troadster
    26Troadster
    i use ether and a clean rag.
