Repair Bullet Holes
Discussion in 'The Hokey Ass Message Board' started by studearch, Mar 11, 2010.
  1. I did a search but didn't find much on how to repair bullet holes. Technical help anyone?
  2. junk yard kid
    junk yard kid
    just like fillin any other hole
  3. dana barlow
    dana barlow
    from Miami Fla.
    Neat coupe;
    There's maybe some trick way I just don't know about?
    I've always bucked and hammer tham as near flat as I can,then welded them up and dress clean after,spot puddy always seemed to do the rest of the smoothy;)
  4. the-rodster
    the-rodster
    I'd reskin the lower part of the p***enger door, and patch the rest.
    Rich
  5. SpazTaztic
    SpazTaztic
    You could always leave them and tell everyone that they are a "feature".
  6. olskool34
    olskool34
    Don't leave the bullet holes in the car, maybe if you put some plastic rats on the hood when you were at shows and painted it flat black with red wheels it would be ok but for a tradional car, fix the holes.
  7. DocsMachine
    DocsMachine
    from Alaska
    Wish I'd had a camera back then, but once I was helping do some work to a buddy's car- a mid-70's Camaro. There was a crack in the paint in front of the rear wheelwell, that clearly showed a layer of bondo.
    Since he was planning to strip and repaint the car anyway, out of curiosity we buzzed the bondo away with a wire wheel.
    It turned out to be a bullet hole that somebody had "patched" by soldering a penny over the "crater", then covered with a skim coat of filler.
    He left it there, far as I know. :D
    Doc.
  8. Them bullet holes are the least of your body working problems! squaring up the whole body and making the doors fit and redoing the roof are going to be way worse than the holes.
  9. dmw56
    dmw56
    You know what I'd do with them! I sold the truck Monday.
  10. 51 Leadsled
    51 Leadsled
    from NC
    Wait at least until they stop appearing before you start to fix them!
  11. 8flat
    8flat
    Just be sure to give your sheetmetal time to cool down when you're welding up the holes out in the middle of those panels...it'll warp pretty easy. Great looking bodystyle though, keep us updated.
  12. bobwop
    bobwop
    from Arley, AL
    I heard you can buy these little round stickers. You put them on a bullet hole and it looks just like smooth sheet metal...or is it the other way around?
  13. garagerods
    garagerods
    from Omaha
    Those holes are character man!
    Now that roof on the other hand......hmmmmm.....
  14. Careful! Bullets really stretch the metal. You'll have to do a **** load of metalwork if you hammer and dolly them, even if they're a .22. I don't think there's a shortcut, jst take the time and do it right. If they're close together or really big, like a shotgun slug, patch them. I have fixed one--in a mini-van side, made by a 9mm, by a policeman that was not minding gnu handling rule #1.
    Good luck!
  15. Hotrod7
    Hotrod7
    :D haha
  16. metalman
    metalman
    Hey, did you just buy that car from Walt?
    Not to be critical but I agree with some of the others, if you have questains on filling bullet holes can you handle the tougher stuff?
    Might want to swing by our HAMB & eggs sometime, several pro builders always there willing to dish out free advice!
  17. David Chandler
    David Chandler
    Only leave them if they are traditional.
  18. As an unarmed Canadian who travels to car shows in the USA from time to time, I would definitely hide the bullet holes. I want any peace officer who sees fit to pull me over - even if just to ask about the car - to be as calm and relaxed as possible. My hands will be in plain view on the steering wheel and I will smile and remember my manners.
    There is no gun rack in my dream truck.
    -Chris
  19. BuiltFerComfort
    BuiltFerComfort
    I read an article where a guy with a ton of bullet holes to fill found a local shop that had an operation that punched out round plugs of sheet metal, which he could buy for s****. Saved him a ton of time on the 100+ bullet holes in his desert find Model A.
  20. Bullet holes? Easy......................................
    Danger,
    Area clear, what happened dig's?...
    Response,
    'What happened dig's?'
    Carryout immediate action...........
    Apply direct pressure with field dressing to bullet wound........................................
    Doc.
  21. blt2go
    blt2go
    i agree with 51leadsled. after the shooting has stopped bullet holes aren't too bad to fix. most times the metal is still all or mostly all there just punched through. hammer and dolly carefully to get the torn pieces back to the surface from the back and weld up. go slow and let things cool. the-rodster suggested skinning the bottom of that door and i agree. there seem to be too many and the door would probably be too stretched and out of shape by the time you got done anyway. good luck.
  22. flatford39
    flatford39
    Make sure you hammer & dolly level and then braze them in. Had a 31 tudor body that had over a hundred of them in it. I used all of my mom's wire coat hangers. It turned out pretty good.
  23. metalshapes
    metalshapes
  24. 32Essex
    32Essex
    from Texas
    Weld on the roof all you want, you can't hurt it.
  25. Hard Luck
    Hard Luck
    HAHAHA !!
    Yeah, I think it's going to take some work to get that roof in shape.
    -Aaron
  26. czuch
    czuch
    from vail az
    Leave em and tell everyone you call it the whistle.
  27. MarkzRodz
    MarkzRodz
    My Gawd!! The level of Cruelty here makes me smile.
  28. ironfly28
    ironfly28
    from Orange, CA
    Those are speed holes....they make the car go faster
