repairs on magnesium valve covers??
Discussion in 'The Hokey Ass Message Board' started by hammeredcoupe, Dec 17, 2009.
  1. hammeredcoupe
    hammeredcoupe
    from Tacoma,WA
    I have a chance to buy a pair of vintage magnesium valve covers for my 392 hemi. The only thing I'm concerned about is the corner of one has a small crack on the corner, like it was dropped. I think if I try to straighten it it will break off. Can this be repaired? Any help or advice would be appreciated. Thanks! Tim
    here's the crack:
  2. plym49
    plym49
    from Earth
    Marine Tex on the inside? Don't know what else to recommend. You certainly don't want to get near it with a torch.
  3. DocsMachine
    DocsMachine
    from Alaska
    Actually, magnesium is quite easy to weld. A block or bar is quite difficult to ignite even intentionally- its only small shavings and dust that's easy, due to the surface area.
    I've TIGged mag several times, with good results. Mag rod is hard to come by- you'll have to special order it- but the actual welding is really no more difficult than doing aluminum.
    On your covers, you'll want to just snap or grind that broken tab off, then build it back up with weld. That piece is small enough there could be some risk of ignition.
    Strongly recommended you weld outside, or on a solid steel table with lots of clearance to anything even remotely flammable- including the ceiling. A couple of big buckets of dry sand as a last-ditch extinguisher can't hurt, or a real Cl*** D extinguisher if you can find one.
    And of course, if you do grind, do it well away from where you'll be welding.
    Doc.
  4. autobilly
    autobilly
    Potentially very cool covers! I don't know much about magnesium, or welding it, but Doc's reply sounds very logical to me.
  5. johnny bondo
    johnny bondo
    from illinois
    yeah just make sure you have a lot of purging. get a dual feed line from your regulator and then put a purge block under it and then use a 3/4 or 1 inch tig shield on your torch. also make sure you dont pull the end of the rod out of the gas while you are welding it.
  6. HOTTRODZZ
    HOTTRODZZ
    Before you fire up the TIG welder bolt a steel chain to your part.
    If it does light up, you can quickly drag it out of your shop.
    Welding old cast Mag is kind like welding old cast aluminum - sometime's its sweet & somtime's its poop - depends on the alloy originally used.
  7. johnny bondo
    johnny bondo
    from illinois
    oh! also make sure you have PRE AND POST flow on your gas!
  8. Captain Chaos
    Captain Chaos
    from Missery
    That lil crack doesn't look like it will affect anything , buy them and run them .
  9. <FANG>
    <FANG>
    from W.L.A.
    Clean up the crack
    A little J&B Weld
    Sand till level
    Bingo!!! Good to GO
  10. humpie
    humpie
    Agree with fang.used jb weld on mine which is alittle bigger crack and it worked fine,and is hard to see unless toure looking for it:D
  11. onlychevrolets
    onlychevrolets
  12. revkev6
    revkev6
    from ma
    I had a main web on an aftermarket VW magnesium case welded up with good result. found the crack on a tear down from a dropped valve on a sat. night race trying to get it together for a sunday race. called up a guy I raced with who welded up magnesium quick changes and he welded it up for me that night. scared the **** out of me when he put a torch on it to pre/post heat it but it came out great and I made the race the next day.
  13. carcrazyjohn
    carcrazyjohn
    from trevose pa
    Heres an idea If your going to polish them ,Solder ,Its just an idea .I dont know if you can get clean enough I personally like the JB weld idea .Magnesium burns very weird .I use to work at a s**** yard and Ive torched mag before .I know it can be dangerous and water fuels the fire.Alumna weld might be another possibility,
  14. 327-365hp
    327-365hp
    from Mass
    Those covers are very cool. I'd buy 'em just to hang on the wall the. It looks like you could run them as is, maybe the JB would look good unless you polish them. Follow Docs advice if you want to fix them right. Here's another tech article by Brian B*** on welding magnesium, good info there.
    http://www.jalopyjournal.com/forum/showthread.php?t=184445
  15. Doc has a handle on it.
    Magnesium is very volitile but it takes a lot to get it started. You can tig weld it no problem. Well No problem is a relative term it does take a bit of talent.
