so I was tightening up my oil pump bolts and one of the heads cracked off luckily i was able to easily remove the rest of the bolt but my question now is do I replace all 4 bolts or just the broken one (which I have already done in the photo) , I only asking because I just want to do the correct thing since once the pans on its done. I'm using zinc plated bolts is that ok as well? Thanks, Joshua
Those are grade 2 … replace with grade 5 although 2 is plenty. I would use star washers. 8 psi torque for grade 2 and 13 psi using grade 5; they are 5/16” co**** ….ACE hardware.
thank you all for the suggestions, I went to ace and bought 4 new grade 5 screws, and then used blue loc***e on all of them.
