replace caddy rear disc brake calipers
Discussion in 'The Hokey Ass Message Board' started by maninacoupe, Oct 26, 2009.
  1. maninacoupe
    maninacoupe
    Hey guy
    Does anyone know if there is a brake caliper that will bolt to the same bracket as a Cadillac Seville rear caliper. 11" brakes with e-brake (ECIs set up). But i will use another type e-brake. So no need for e-brake on calipers.
  2. draggin breath
    draggin breath
    I think any metric GM front will work. i'll buy your trashed Seville ones for cores.
  3. Hackerbilt
    Hackerbilt
    Aren't there two different sizes to the Caddy rear caliper pistons, depending on year?
    Better be sure your replacement calipers have pistons of the same size or your braking will be affected.
  4. maninacoupe
    maninacoupe
    They are 1977 Cadillac Seville and Buick Riviera I believe.
  5. Scarebird
    Scarebird
    Alliance Vendor
    from Moita, PT
    what is the distance between caliper bolt pins?
  6. ECIGUY
    ECIGUY
    Call me and I'll tell you what you need to know.
