Replacement '54 Chevy gauges
Discussion in 'The Hokey Ass Message Board' started by hotrod54chevy, Jul 17, 2011.
  1. hotrod54chevy
    hotrod54chevy
    from Ohio
    Wanting to replace my Chevrolet's gauges. I have the stock bezel and speedo, with what looks like a plastic panel and autometer gauges I don't care for. While I keep my eyes peeled for a stock unit, does anyone know of some aftermarket or reproduction gauges that'll fit and look stock? I wouldn't have the stock ones redone, I'd just use a voltage reducer, as I've seen on The H.A.M.B. :) I'm just tired of these out of place gauges. Any thoughts, guys? Thanks!
  2. LeftCoastErik
    LeftCoastErik
    check out Dolphin gauges. I got one of their replacement panels for my 50 (single setup) with antique beige style gauges and they look pretty good in the car.
  3. MORRISGAUGE
    MORRISGAUGE
    The originals are higher quality than anything you can buy today.
  4. CopperBandit
    CopperBandit
    from New Jersey
    Yeah I bought dolphin gauges for my 53 as well. They fit nicely and dont look too hoakie.
  5. hotrod54chevy
    hotrod54chevy
    from Ohio
    MORRIS: I know, right?? But I need to know what's readily available!
  6. Gabriel Howard
    Gabriel Howard
    from OKC
  7. marks914
    marks914
    Alliance Vendor
  8. hotrod54chevy
    hotrod54chevy
    from Ohio
    Sorry, I should've been specific. A '54 Chevrolet car, not truck.
  9. big creep
    big creep
    why not get them rebuilt? pricey, but worth it!
  10. skyrodder
    skyrodder
    the Autometer Cruiser gauges are pretty cool looking too
  11. hotrod54chevy
    hotrod54chevy
    from Ohio
    Big creep: need to get a set 1st! Plus it depends on how bad they are. Oh, and I'm cheap. :D
  12. MORRISGAUGE
    MORRISGAUGE
    The labor of restoration is never cheap. I would find a set here or on eBay that is guaranteed to come functional, then have them checked out by a gauge shop. A basic test, maybe a speedometer rebuild and voltage conversion shouldn't run more than a couple hundred $.
  13. chopolds
    chopolds
    from howell, nj
    I am not sure I have pics of it somewhere, but when i did my 54, I made a sheet metal plate that sat behind the bezel. I cut out 4 ovals (hole saw+cut off tool), 2 up high, and 2 lower, staggered. I took the bezels, and lenses off 4 S-W gauges, and mounted them behind the ovals, with machine screws welded to the backsides, so no hardware showed.
    I then painted the sheet metal to match the dash, and used rub-on transfer lettering to "name" the gauges, then clearcoated it.
    Looked good, almost factory, and easily replaced the gauges, if one failed. Also had the correct voltage, and pressure/temp ranges for a modern V-8.
    I used ovals so they kind of matched the shape of the factory bezel better, and didn't look so "added on" like aftermarket gauges usually do.
  14. big creep
    big creep
    hahaha, im not cheap just broke! i got lucky and found a set for my shoebox already done in the hamb cl***ified!
  15. jrlemke
    jrlemke
    I put a '72 Firebird speedo and gauges from about a '70 Olds 442 in my '52 Chev bezels with very little triming. Used sending units to match gauges. The only problem I found was the dashlites were a little shadowed. Could be corrected simply, but I didn't want to take everything apart again. Jim
