Replacement fan for my 390 FE
Discussion in 'The Hokey Ass Message Board' started by rdtreur, Oct 10, 2011.
  1. rdtreur
    rdtreur
    The fan on my '64 Merc 390 FE is bended and out of balance. So I want to replace it. I have a good working fan clutch and I want a new fan that will work with the clutch.
    Any ideas? Will a flex-fan work on a clutch?
    Many thanks, Ramon
  2. rdtreur
    rdtreur
    Any help please...
  3. rom828
    rom828
    the idea behind a fan clutch is that when the engine doesn't need to be pulling air through the radiator, it disengages the fan so that it will freewheel and not be a drag on the engine. There are two types, centrifical, that cuts out at higher RPM's and thermostatic that engages the fan at higher temps. I like the thermostatic. A flex fan flattens out at higher RPM when your going down the road and don't need air being pulled through the radiator. Just get a matched fan and clutch from a 70's Ford big car or truck with AC and you'll be fine. That's what I run on my O/T '69 F100 with a 390 and it works great.
  4. rdtreur
    rdtreur
    Thanx for the info. The problem is that i live in the Netherlands and 70's Fords are not that common on the junkyards.... So i'm looking for a new fan that i can order from someone like Summit/jegs.
  5. rom828
    rom828
    After I posted it I thought that old Fords are probably not common where you're at. Summit can get you a thermo clutch and matching fan. Tell them it's a 1976 LTD, 351M with A/C. I wouldn't use an aluminum flex fan after seeing one come apart, (not pretty). I stay away from "high performance" parts like this because IMHO, they are junk.
  6. TooManyFords
    TooManyFords
    from Peotone IL
    Clutch fan is the way to go. I have seen flex fans go through hoods. Would not use them.
  7. RustyNCA
    RustyNCA
    Not to confuse the issue, but I happen to be running a heavy duty thermo clutch and fan on my 58 TBird with a 390 that I orginally got from Summit for my 68 olds with a 455.
    I also would stay away from the flax fans after seeing one come apart and eating up the radiator on my dad's Landscruiser in the middle of the desert.....
  8. rdtreur
    rdtreur
    Thanks Rom, I found out that I need the Flex-a-lite clutch type fan. I didn't know flex-a-lite made stock replacemend fans.
    There are no better parts then stock toyota parts, I know from my experience in the Amsterdam to Dakar challange in a 1986 Toyota pickup
    Thanx for the info guys,
    Ramon, Amsterdam
