Customs Replacement for 1949 Ford Tudor seats
Discussion in 'The Hokey Ass Message Board' started by Babyboomerboy, Jan 5, 2023.
  1. Babyboomerboy
    Babyboomerboy
    Is there a seat from another vehicle that I would bolt straight into my 49 Ford Tudor? Thank you
  2. alchemy
    alchemy
    Probably a 50 Ford?
    X38 and Tman like this.
  3. Babyboomerboy
    Babyboomerboy
    I think a 50 or 51 seat would work but I was hoping there was a newer vehicle that had the same or close to the same bolt pattern. Thank you for your reply
  4. alchemy
    alchemy
    Usually working on old cars isn't as lucky as that.
    X38 and sidevalve8ba like this.
  5. '49 Ford Coupe
    '49 Ford Coupe
  6. alchemy
    alchemy
    A fordor seat wouldn't be any good, it won't tilt forward so the p***engers can get in back.
    '49 Ford Coupe likes this.
  7. chopped
    chopped
    Should be easy enough to make an adapter to fit almost anything. May only need some flat stock.
  8. '49 Ford Coupe
    '49 Ford Coupe
    Good point!!!!
  9. '49 Ford Coupe
    '49 Ford Coupe
    You might call Roger or Lynne at 620.680.0449 or 620.680.0375..they have some shoeboxes that are being parted out. That's where I got my seats..in Kansas
  10. Packrat
    Packrat
    Put an ad in the wanted section here, that's how I found the seat in my 40.
  11. 24riverview
    24riverview
